I have a muniac drastic lightfoot hub with modified kooka cranks. I am looking to put longer cranks on this hub and was wondering what other cranks may be easily modified to fit this particular hub besides Kookas. Also, which kookas can be modified. The set that i have is very solid with no relief in the crank arms so there is plenty of metal to modify. I have seen other kookas with more relief in the crank arm and less metal around the taper hole, would they work? Any info would be helpful. BTW i am looking for 175mm cranks for my 26"muni.
Re: Cranks for the Muniac Hub???
Can you retrofit new cranks yourself? I thought for the Muniac hub,
you had to return it to the Muniac for new cranks. So why not ask him
for advice then (assuming he is still in business now that his
unicycling website is down).
Klaas Bil - Newsgroup Addict
“I’m slowly but surely stealing Wales and bringing it back to my house on the wheel, frame and cranks of my muni. - phil”
