i can do crank grabs i learned today any tips of what i shud do next:D
God!
The uni champion is here!
Pedal grabs?
start your pedal grabs
i can do them too. wat next
Pedal grab on to higher things.
âwhy stop at pedal grabsâ?
Hey you, bet you canât fly over that small industrial wherehouse!
I bet he can if he uses enough TNT.
lol I learned them today to! (well sorta)
can you hop up from the crank grab?
If he canât then itâs not a crankgrab.
well it is a crank grab but it isenât a fULL crank grab
Learn how to pull from crank to rubber would be the most obvious thing. Itâs pretty easy once you do it but it takes some nerve.
Yeah, most people I see when learning tense there legs up right before they jump, and then they either dont get to rubber, or they just stay down like they are about to jump, but never do.
Be relaxed, and be able to jump without the tires compression. Jump and pull up on the handle, and your really dont need to lean over much at all to get your tire on the object. =p
Maestro wrote out a really good guide on them. Search for that.
hey i almost have it down, it must be a good day. I can get to rubber but I always roll forward and fall and if I put more weight on the back foot I canât get up, any tips
Thatâs freaking radical, radical reed!
Try going up, and not rolling out of it. Just get up and hop until your balance is restored, and then role out of it. Practice this and after a bit you should be able to do it smoothly.
This is a crank grab right?
Yeah, going from a crank/pedal grab to a crank climb is your best move, because learning this can open up a lot of obstacles that are too hight to simply hop onto. Itâs a lot harder to learn if you have a 24" than a 20 though.
yup its a crank grab. unfortunately I canât even get get my balance:o I just roll forward so fast I fall off. should I be grabing with my front foot or back?
Thanks for the help though!
-Reed
Just go with whatever feels more comfortable âŚif something feels funny try mixing it up a bit until you find what helps youâŚthese took me a while to learn but they really do come in handy.
Whoa, chillax home fryâŚWell dude you can try doing the same height grabs but with only one hop straight to rubberâŚand you can work on skinnies tooâŚ
I believe itâs called a crank stall.
hey so i can do a full crank stall on a table bench pretty good.
and ive been tryin to hop straight onto the bench.
i finally got good enough to hop all the way up. but i kind of fall over to the left from leaning to far over for my jump.
so i guess what im sayin is i cant maintain controll or balance after i land on the bench.
how do i fix this?
