Re: crank comes loose all the time!
Mikefule <Mikefule.6rhzb@timelimit.unicyclist.com> wrote:
This is an excellent description of how to put on cotterless cranks.
Please allow me to make a few comments based on my own experiences.
>I doubt the Loctite is relevant as it will only stop the nut unwinding
>on the thread. Given enough persuasion, the nut will loosen anyway - it
>has to otherwise no one would ever use Loctite because they wouldn’t be
>able to remove the nut later if they wanted to.
The crank must be pounded on tightly. The nut is really only able to
keep the crank on tight, the nut itself is on very tight.
>My guess is that either you are not seating the crank properly on the
>tapered end of the axle, or the taper is damaged, worn, or faulty.
>Try this two-pronged approach:
>1) Remove the other crank and refit it at 90 degrees to its original
>position. (Do it in this order so you have a reference point.)
>2) Remove the offending crank and fit it appropriately - i.e. at 90
>degrees to its original position, and at 180 degrees to the new position
>of the other crank.
>(My theory being that if the taper is worn, faulty or damaged, this will
>have been exacerbated by the constant loosening during use, and the wear
>will be distributed on the taper in one direction because the pedaling
>force is always in the same direction.)
If the crank hole for the axle is no longer square (is more rounded than
its original square shape), toss it and buy new crank arms.
>3) Now, before tightening the nuts, find a large block of wood and a
>heavy soft mallet - ideally wooden or rubber, but copper faced might
>do.
In my experience, a rubber mallet is too soft to get the crank on tight
enough. A wooden mallet should work fine (or hardwood block and steel
hammer combo). A copper faced or brass mallet should also work fine.
The brass mallet might be a bit too hard for this application, so some
restraint in its use would be advised.
>4) Using the block of wood as an anvil, and perhaps asking a friend to
>hold the uni straight, position the uni so that the axle is vertical,
>with one crank resting on the block of wood.
>5) Now wallop the top crank at the centre to drive it onto the taper.
>The important thing with the hammer is to use the weight and balance of
>the hammer to deliver the force, and to strike confidently ‘through’ the
>target, rather than tapping away at it lots of times.
>6) Tighten up the nut for the crank you’ve just walloped on.
I’d repeat steps 5 and 6 about three times for each crank arm. Doing
this properly will likely tighten the crank on the taper so well, that
it may never come loose (until the nut is loosened).
>7) Now flip the uni over and do the same for the other crank.
>(What you have now done is realign the cranks by 90 degrees to
>counteract any uneven wear on the taper, then seated the cranks very
>firmly on the tapers, then tightened the nuts up to draw the cranks on
>fully.)
>8) Leave the dust caps off for now, and carry a 14 mm socket or use the
>crank tool and a spanner. Ride for a bit, idle for a bit, but don’t
>wait for the cranks to feel loose. Then nip the crank nuts up just that
>bit tighter.
I’ve never had to do this step for any crank in which I repeated steps 5
and 6 at least three times total.
>(You will find that crank nuts come loose every few hours of riding
>anyway. I seldom ride anywhere without the necessary tools, because
>riding with a loose crank is annoying, and it damages the crank or,
>worse still, the taper.)
If both the crank arm and crank retaining nut are both made extremely
tight using the above procedure, neither the crank or its retaining nut
will ever come loose.
To remove crank arms: Loosen the retaining nuts each about a few
rotations. Do some hard idling or riding until both cranks feel
slightly loose, being careful that the retaining nuts don’t become too
loose. If one crank becomes too loose, its retaining nut has become too
loose and should be tightened a bit. When both cranks are slightly
loose, a cotterless crank removal tool should easily finish the job.
[Due to the force used in pounding the cranks on, using only the crank
removal tool could strip out the corresponding threads in the crank, so
please use the loosening up procedure at the beginning of this
paragraph.
Sincerely,
Ken Fuchs <kfuchs@winternet.com>
