This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
----__JNP_000_7160.0e35.667d
Hi again, Recently, my new muni (with, yes, Lasco cranks) started to make
noises that sound like a “clunk”. At first I thought it was a spoke, but I
realized that I was able to feel a small bump in the left pedal. The only
time that I felt or heard anything was when I was pedaling hard (like
climbing, descending, accelerating, etc.). A recent article about bottom
brackets in Adventure Cyclist by bicycle guru Sheldon Brown has led me to
believe that the culprit for all the trouble is a loose or faulty crank.
So, I tightened up the left crank, but I still hear and feel the clunk. Is
their anything else I should do before I toss the cranks? Please note:
these are Lasco aluminum cranks and I have done a few big drops on them.
Also, I installed them myself (which could cause a few problems :-D).
Thanks! Jeff T. ----__JNP_000_7160.0e35.667d Content-Type: text/html;
charset=us-ascii
<!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.0 Transitional//EN”>
<HTML><HEAD> <META http-equiv=3DContent-Type content=3D"text/html;
charset=3Diso-8859-1"> <META content=3D"MSHTML 5.50.4611.1300"
name=3DGENERATOR></HEAD> <BODY bottomMargin=3D0 leftMargin=3D3
topMargin=3D0 rightMargin=3D3>
<DIV>Hi again,</DIV>
<DV> Recently, my new muni
(with= ,=20 yes, Lasco cranks) started to make noises that
sound like a “clunk”.&= nbsp;=20 At first I thought it was a spoke,
but I realized that I was able to feel a=
=20
small bump in the left pedal. The only time that I felt or heard anything
= was=20 when I was pedaling hard (like climbing, descending,
accelerating, etc.). A=
=20
recent article about bottom brackets in <EM>Adventure Cyclist </EM>by =
bicycle=20 guru Sheldon Brown has led me to believe that the culprit for
all the = trouble is=20 a loose or faulty crank. So, I tightened up the
left crank, but I still = hear and=20 feel the clunk. Is their anything
else I should do before I toss the cranks= ?=20 Please note: these are
Lasco aluminum cranks and I have done a few big = drops on=20 them. Also,
I installed them myself (which could cause a few problems=20 :-D).</DIV>
<DVI> </DIV>
<DVII>Thanks!</DIV>
<DVIII>Jeff T.</DIV></BODY></HTML>
----__JNP_000_7160.0e35.667d–
GET INTERNET ACCESS FROM JUNO! Juno offers FREE or PREMIUM Internet access
for less! Join Juno today! For your FREE software, visit: http://dl.www.juno.com/get/tagj.
— jeff d tuttle <moosebreath1@juno.com> wrote: > Hi again, Recently, my new muni (with, yes, Lasco cranks) started to > make noises that sound like a “clunk”. At first I thought it was a > spoke, but I realized that I was able to feel a small bump in the left > pedal. The only time that I felt or heard anything was when I was > pedaling hard (like climbing, descending, accelerating, etc.). A recent > article about bottom brackets in Adventure Cyclist by bicycle guru > Sheldon Brown has led me to believe that the culprit for all the trouble > is a loose or faulty crank. So, I tightened up the left crank, but I > still hear and feel the clunk. Is their anything else I should do before > I toss the cranks? Please note: these are Lasco aluminum cranks and I > have done a few big drops on them. Also, I installed them myself (which > could cause a few problems :-D). > > Thanks! Jeff T.
If the crank is damaged badly enough during a drop (due to poor materials,
loose crank nut in the first place, etc.) it will flop even after you
re-tighten the crank nut. You should be able to verify that it’s the crank
by holding the wheel between your legs and pulling hard back and forth on
the end of the crank arm. It will probably wobble a good quarter inch or
so. Time for new cranks if this is the case, but the good thing is the
Lascos are too soft to hurt the axle so if you can put up with that floppy
feeling you can keep riding them. At least until your new ones come in the
mail/paycheck.
Chris
> jeff d tuttle wrote: > > Hi again, Recently, my new muni (with, yes, Lasco cranks) started to > make noises that sound like a “clunk”. At first I thought it was a > spoke, but I realized that I was able to feel a small bump in the left > pedal. The only time that I felt or heard anything was when I was > pedaling hard (like climbing, descending, accelerating, etc.). A > recent article about bottom brackets in Adventure Cyclist by bicycle > guru Sheldon Brown has led me to believe that the culprit for all the > trouble is a loose or faulty crank. So, I tightened up the left crank, > but I still hear and feel the clunk. Is their anything else I should > do before I toss the cranks? Please note: these are Lasco aluminum > cranks and I have done a few big drops on them. Also, I installed them > myself (which could cause a few problems :-D). > > Thanks! Jeff T.
Nick Dangerously wrote: > > Im sure youve czeched this, but even so: > > look at your pedals. my left pedal comes loose every 15 or 20 minutes of > hard riding, no matter how i tighten it. This makes it clank. Just a > thought.
Your PEDAL?? Is by any chance your seat on backwards?
> If the crank is damaged badly enough during a drop (due to poor > materials, loose crank nut in the first place, etc.) it will flop even > after you re-tighten the crank nut. You should be able to verify that > it’s the crank by holding the wheel between your legs and pulling hard > back and forth on the end of the crank arm. It will probably wobble a > good quarter inch or so. Time for new cranks if this is the case, but > the good thing is the Lascos are too soft to hurt the axle so if you can > put up with that floppy feeling you can keep riding them. At least until > your new ones come in the mail/paycheck.
Maybe… When my Lascos got bad enough that I could feel 'em flopping
around, they were only good for just a few more minutes of riding before
they got so bad that it was useless riding on 'em.
— Chris Reeder <reed8990@uidaho.edu> wrote: > Nick Dangerously wrote: > > > > Im sure youve czeched this, but even so: > > > > look at your pedals. my left pedal comes loose > every > > 15 or 20 minutes of hard riding, no matter how i tighten it. This > > makes it clank. Just a thought. > > Your PEDAL?? Is by any chance your seat on backwards? > > Chris
