Last time I followed Sam’s directions for converting .mp3 files to .wav files for videos it worked perfectly. I seem to be doing the same thing this time but when I click ‘play’ it actually plays the song and doesn’t convert it. Is there anything I can check?
Goto properties and make sure that in the output section it is set to ‘nullsoft dic writer’ and not anything else.
If it isnt set to the disk writer plugin you need to change it back to it, otherwise it will just play the files as songs.
Enjoy.
Speaking of mp3, has anyone heard Hot Hot heat’s new album?! Awesome!
It was definately on the right output thing. I just upgraded to Winamp 3. Do you have that? Could you tell me how to do it using that? It doesn’t work the same way.
I found this to be about the best audio conversion tool. It’s very easy to use but if you have any questions just ask. Of course I don’t read this forum very often, but I’m sure someone could help.
I use CDex for ripping several tracks from CDs, but for converting the occasional single track between formats I use DBPowerAmp (http://www.dbpoweramp.com). This adds a “Convert To…” option to the menu when you right click on a music file, so it’s really easy to use.
