Contemplating a Hatchet next
Hi there, currently own a Nimbus Oracle 29" which I use for riding around light trails etc. I don’t ride as much as I’d want to but I’m finding as with any activity if you don’t use it enough the skills fade. As such I gravite towards the easier stuff each time I ride and as such my rusty manoeuvres just don’t improve.
Originally I started out on a steel framed 26" Nimbus Muni which I rode lots and my where I essentially cut my teeth on all the basics I know now. The 26" became unused and as such I decided to let that it go in favour of a larger wheel.
As per the title I’m thinking about investing in a smaller wheel at least as an alternative to bring back some confidence. I’ve considered the Hatchet in the past but for one reason or another I opted for a 29" as I thought it would be the best compromise between covering distance and off-road ability.
I’m returning to my thoughts about getting a Hatchet as I like its looks and compliments about it’s offroad ability. Initially I thought the 26" one looked good but I’m put off by the seemly impossiblilities of getting hold of a replacement tyres should I ever need them as no one in the UK appears to sell them. However the 27.5" Hatchet looks to fit the bill and have considered this could be a better option (?). I won’t venture to a 29" as it seems pointless since I already have the Oracle.
I can’t find much in the way of folks who own a 27.5" Hatchet on here, or maybe they enjoy them that much that are too busy to post about them.
What are your thoughts?
Cheers
The hatchet is specifically made to be able to run fat tires. A fat 27.5" (3.8" or similar) is almost same diameter as a 29"-3.0. So you are really not getting a smaller wheel - but obviously a very different wheel that can run at very low pressure offroad. If you are not interested in fat wheels the hatchet seems a bit pointless to me (except for the cool looks!) as you could just as well get a 27.5" wheel built and mount it in your existing 29" Oracle frame and save money and weight. You could even reuse the hub if you want.
