A few days ago I posted a message regarding a problem with an AGP slot.
After further research, looks like it might not be the AGP slot after all.
Basicly, the problem is that when I connect my monitor to the computer it
acts as if it is not connected to anything, displaying a “Check Signal
Cable” message. At first I thought that the problem was with the AGP slot
and after trying two AGP video cards, I went ahead and purchased a PCI one.
However, I am having exactly the same problem with the PCI video card.
I tested the monitor with a different computer (the one I am using right
now) and it works perfect, so the problem is with the PC. Any ideas on what
could be wrong?
Re: Computer Problem - may be AGP, maybe motherboard
giggle the cable?
hit it?
“Yevgeniy Leshchinskiy” <webmaster@animationlibrary.com> wrote in message news:b7o8vs$g8h$1@www.darklock.com…
one.
what
> could be wrong?
Monitor or computer? Well, I hit both just in case. Doesn’t help
all.
it
slot
> one.
> what
> > could be wrong?
Have you tried a different cable?
Gary Stein
“Yevgeniy Leshchinskiy” <webmaster@animationlibrary.com> wrote in message news:b7om4n$u1k$1@www.darklock.com…
> “Tony Ranieri” <Tonywd@woogu.com> wrote in message
> news:b7oeqe$m7q$1@www.darklock.com…
> > giggle the cable?
> Did that. Tried replacing the cable as well.
> > hit it?
message
> > news:b7o8vs$g8h$1@www.darklock.com…[color=darkred]
> > > A few days ago I posted a message regarding a problem with an AGP[/color]
slot.[color=darkred]
> all.
> it
> slot
> > one.
> > > I tested the monitor with a different computer (the one I am using[/color]
right[color=darkred]
> > what
> > > could be wrong?
>[/color]
Yep
“Gary Stein” <gestein@cnw.com> wrote in message news:b7oqu9$3fi$1@www.darklock.com…
> Gary Stein
> > news:b7oeqe$m7q$1@www.darklock.com…[color=darkred]
> > > giggle the cable?
> > > hit it?
> message
> slot.
> > > > After further research, looks like it might not be the AGP slot[/color]
after
> > all.[color=darkred]
> > > > Basicly, the problem is that when I connect my monitor to the[/color]
computer
> > it[color=darkred]
> > > > acts as if it is not connected to anything, displaying a “Check[/color]
Signal[color=darkred]
> > slot
> > > > and after trying two AGP video cards, I went ahead and purchased a[/color]
PCI[color=darkred]
> > > one.
> > > > However, I am having exactly the same problem with the PCI video[/color]
card.[color=darkred]
> right
> > > > now) and it works perfect, so the problem is with the PC. Any ideas[/color]
on[color=darkred]
> > > what
> > > > could be wrong?
>[/color]
Have you tested the AGP card with another computer? (I know you said
monitor, but what about the card…?)
> could be wrong?
If two different cards (he tried AGP and PCI) do not work, I would
assume it is a motherboard problem or software problem. I’d sugest that
you check the BIOS settings to see if there is anything set weird in
there for the video stuff.
Gilby
>> all.
>> one.
>> what
>> could be wrong?
You know I have a viewsonic monitor that just won’t work right with my
PC. It works with other PCs, as a matter of fact when I sent it in to
Viewsonic for them to fix it, they sent it back untouched because there
was nothing wrong with it.
But it just won’t work right with the GeForce3 card I’ve got in my Asus
motherboard… the red flickers in and out annoyingly.
Strangely enough I upgraded the video drivers recently and now the
flicker happens less often… still there but less.
> - Gilby
>>[color=darkred]
>>> all.
>>> computer it
>>> slot
>>> PCI one.
>>> on what
>>> could be wrong?
>[/color]
Is there a way to check the BIOS without the monitor? I thought it could
only be accessed with F10 (or F2)
Yevgeniy
“Gilby” <mail@gilby.com> wrote in message news:b7p1a0$a45$1@www.darklock.com…
> - Gilby
> >[color=darkred]
> >> all.
> >> Basicly, the problem is that when I connect my monitor to the computer[/color]
it[color=darkred]
> >> Cable” message. At first I thought that the problem was with the AGP[/color]
slot[color=darkred]
> >> one.
> >> what
> >> could be wrong?
>[/color]
one.
what
> could be wrong?
> It doesn’t have an on board video that it might have defaulted to does it?
I don’t think it does, at least it came with a separate video card. Any way
to check?
> When you call dell they don’t care that the computer no longer works?
I didn’t buy an extended warranty. Under the limited warranty, they can take
a look but
I have to pay shipping
It may take up to 4 weeks
They don’t guarantee integrity of the data on the drive
> When you turn on your comptuer is anything happening at all? Does the
> processor get warm? Do fans spin…hard drive…etc?
Yes, everything else seems to work, or at least sounds as it does.
> Adam Gordon
> SBA Design - web development and hosting
> http://www.sbadesign.com
> adam@sbadesign.com
all.
it
slot
> one.
> what
> > could be wrong?
it?
way
> to check?
Yes, easily. Can you plug in your monitor anywhere else on the back of the
computer?
take
> a look but
> 1) I have to pay shipping
> 2) It may take up to 4 weeks
> 3) They don’t guarantee integrity of the data on the drive
You shoudl be able to disconnect the hard drive and ship it without it. You
can ask them on the phone first if you wanted. I haven’t had much
experience with Dell. But at work we have a lot of Gateways, and when we
ship laptops back to them we take the hard drive out, and usually the
battery…etc. They don’t need any of that to test out the video card
problem, as there would be something to display right when it’s turned on.
Adam Gordon
“Adam Gordon” <adam@sbadesign.com> wrote in message
the
> computer?
Doh! No, I don’t have an onboard card.
You
> battery…etc.
Hmm, good tip, I will ask regarding taking out the HD.
If it is in fact a motherboard problem, are Dell’s motherboard’s replaceable
by non - Dell ones? I looked at the board and got an impression that it
would be quite difficult to remove.
> - Gilby
> >[color=darkred]
> >> all.
it[color=darkred]
slot[color=darkred]
> >> one.
> >> what
> >> could be wrong?
>[/color]
My past experience with Dell machines is that they use non-standard
connections to the power supply and thus if you want to change the
Motherboard you have to also change the power supply. That was about 5 years
ago I do not know if they still do that or not.
Gary Stein
“Yevgeniy Leshchinskiy” <webmaster@animationlibrary.com> wrote in message news:b7u332$k98$1@www.darklock.com…
replaceable
> > - Gilby
> > Shena Delian O’Brien wrote:[color=darkred]
> > >> all.
computer
> it[color=darkred]
> slot
PCI[color=darkred]
> > >> one.
> right
on[color=darkred]
> > >> what
> > >> could be wrong?
>[/color]
Problem fixed
one.
what
> could be wrong?
What was the problem? How did you fix it?
> Problem fixed
> one.
> what
>>could be wrong?
My lamp which I have connected to the same outlet short-circuited (I was not
aware of this as I use the lamp rarely). The charge was mostly stopped by
the surge protector, preventing it from frying the computer, but some of it
got through.
At the end, the problem was solved by taking out the battery which powers
the BIOS, letting it discharge for about 5 minutes and putting it back in. I
lost the BIOS settings but they were easy to restore.
Eugene
“Shena Delian O’Brien” <shena@darklock.com> wrote in message news:3EA40AF2.5060209@darklock.com…
> > Problem fixed
message
> >[color=darkred]
> >>After further research, looks like it might not be the AGP slot after[/color]
all.[color=darkred]
it[color=darkred]
slot[color=darkred]
> > one.
> > what
> >>could be wrong?
>[/color]
That is the strangest most non-linear problem I have ever heard. I would
never have figured that out if it had been mine!
> got through.
I had no clue either. I showed the computer to a friend, an electric
engeneering major, and he figured out in about 10 mins.
“Shena Delian O’Brien” <shena@darklock.com> wrote in message news:3EA5677C.1030706@darklock.com…
not
by
it
> > got through.
powers
in. I
