Computer parameters
Ok a few questions concerning heat in my new setup. the processor tops at
about 109(Athlon), while the case is around 80. Are thsoe reasonable, or
shopuld I try to get more air moving through the system. If so what are
some other ways of cooling the case down with no more places to put a fan
on the case. Do they have fans that fit in the HD bay but act as fans
still?. I thought I saw a couple of those before.
Thanks
Brian Wilmot http://www.jumpnow.net/ http://www.uglybillboards.com/ “You
can die but you’re never dead” - Red Hot Chili Peppers
“Brian Wilmot” <bwilmot@jumpnow.net> wrote in message
news:9hg9km$aqv$1@constitution.worldwebserver.com
> at about 109(Athlon), while the case is around 80. Are thsoe
> reasonable, or shopuld I try to get more air moving through the system.
> If so what are
some
Yes, that is fine.
> other ways of cooling the case down with no more places to put a fan on
the
> case. Do they have fans that fit in the HD bay but act as fans still?. I
http://www.hardocp.com http://www.3dcool.com
Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace(
“osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) ->
http://thedoh.dyndns.org/hexrgb/index.php
there are slot coolers, things you can screw in the back of the computer
in the slots where youd have something like the video card connectors and
such… there are also various sorts of hard drive coolers and the coolers
that fit into the bays… http://216.157.14.244/hdcool.htm
Tony Raineri http://www.woogu.com
> If so what are
some
the
> Thanks
> Brian Wilmot http://www.jumpnow.net/ http://www.uglybillboards.com/ "You
> can die but you’re never dead" - Red Hot Chili Peppers
I like the video card/pci slot cooler…inexspensive but works well(or at
least it appears that way.)
I assuming my computer will get hotter than I said before at times becasue
the longest its been on is 3 hours at light duty. So far that is.
can die but you’re never dead” - Red Hot Chili Peppers “Sean S.”
<noemail@here.blargh> wrote in message
news:9hg9vb$ato$1@constitution.worldwebserver.com
at
> > or shopuld I try to get more air moving through the system. If so
> > what are
> some
> Yes, that is fine.
> > fan on
> the
worked well in my box, think mine was ~$13 and dropped my temp 10F, but i
put it right under the video card too, so results will vary depending on
where in the case it goes
news:9hgcn6$bkn$1@constitution.worldwebserver.com
> becasue the longest its been on is 3 hours at light duty. So far
> that is.
