I’m trying to shorten the hose on my magura and was wondering if they’re is a trick to getting the compression ferrule on. Thanks.
You cannot reuse the fittings that are used on the plastic Magura brake hose. You need to start with brand new fittings.
For instructions on shortening the brake hose look at the Magura shop manual available here: Magura downloads
There are also some good tips at the Magura Cult
