CokerChef
This is a multi-part message in MIME format.
------=_NextPart_000_000B_01BFD8AC.335BEC20 Content-Type: text/plain;
charset=“iso-8859-1” Content-Transfer-Encoding: quoted-printable
Well, I finally got my Coker, after 3 years of hinting, nagging, and = spamming
my wife with newsgroup postings about how great they were. So = I open the box,
pull out the fork and tire, and look inside an empty = box- no pedals, seat,
post…nothing! =20
Fortunately, I have 5 more unis in the garage. So I extrapolated the =
pedals off my Sem, and the seat off my homemade giraffe and took off. = What
a blast!=20
Question- what kind of seat does the Coker come with? I am really = spoiled
now with the Sem Deluxe seat and inner tube cushion. Will a Sem = seat fit
on a Coker?
And yes- my wife called the folks at Unicycle.com and they are sending = out the
parts first thing Monday. They were very apologetic. They box = was intact from
what I could tell, they must not have been packed at the = factory- you just
can’t find good child labor in Taiwan these days!
Mike Bersell UniChef.com www.unichef.com unichef@unichef.com
------=_NextPart_000_000B_01BFD8AC.335BEC20 Content-Type: text/html;
<!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.0 Transitional//EN”> <HTML><HEAD>
<META content=3D"text/html; charset=3Diso-8859-1" = http-equiv=3DContent-Type>
<META content=3D"MSHTML 5.00.2614.3500" name=3DGENERATOR> <STYLE></STYLE>
</HEAD> <BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Well, I finally got my Coker, after 3 =
years of=20 hinting, nagging, and spamming my wife with newsgroup
postings about how = great=20 they were. So I open the box, pull
out the fork and tire, and look = inside=20 an empty box- no pedals,
seat, post…nothing! </FONT></DIV>
<DV> </DIV>
<DVI><FONT face=3DArial size=3D2>Fortunately, I have 5 more unis in =
the=20 garage. So I extrapolated the pedals off my Sem, and the
seat off = my=20 homemade giraffe and took off. What a blast!
</FONT></DIV>
<DVII> </DIV>
<DVIII><FONT face=3DArial size=3D2>Question- what kind of seat does the = Coker
come=20 with? I am really spoiled now with the Sem Deluxe seat and
inner = tube=20 cushion. Will a Sem seat fit on a
Coker?</FONT></DIV>
<DIX> </DIV>
<DX><FONT face=3DArial size=3D2>And yes- my wife called the folks =
at=20 Unicycle.com and they are sending out the parts first thing =
Monday. They=20 were very apologetic. They box was intact
from what I could tell, = they=20 must not have been packed at the
factory- you just can’t find good child = labor=20 in Taiwan these
days!</FONT></DIV>
<DXI> </DIV>
<DXII><FONT face=3DArial size=3D2>Mike Bersell<BR>UniChef.com<BR><A=20
href=3D"http://www.unichef.com">www.unichef.com</A><BR><A=20 href=3D"mai-
lto:unichef@unichef.com">unichef@unichef.com</A></FONT></DIV><=
/BODY></HTML>
------=_NextPart_000_000B_01BFD8AC.335BEC20–
RE: CokerChef
If building your own giraffe…
> Then I found instructions on the internet that were made by someone who never
> rode a uni, much less built a giraffe. I tore those up.
Good advice. Thought the design of a non-rider might make an excellent cycle,
why take a chance? Use a design that has already resulted in good unicycles.
> The steel I used was too heavy. It is hard to pedal, especially uphill.
Heavy is something you should probably put up with on a home made. Try to make
it as light as a factory-built machine and you take a big risk of breakage. Tom
Miller’s home made giraffes are heavy, but pros around the world use them
because they can take the beatings of professional use.
> From being so heavy, every time I dropped it (which was a lot because I was
> just learning) it would slam down on the seat and post, putting stress on the
> joint just above the crank, which I have welded and reinforced 3 times.
Traditionally the weakest spot on a giraffe frame is the weld on top of the
crank barrel (as described above). If I were building one I would automatically
add gussets there; one in front and one in back of the joint. I wouldn’t want
that spot to break while I was riding…
Ride on, builders… John Foss, the Uni-Cyclone http://www.unicycling.com
“I thought it was Memorial week!” - Austin Miller, 8, on being told he had to
get up for school on the Tuesday after Memorial Day
Re: CokerChef
Camilo-
I also looked for instructions on how to make a giraffe. I found some in a book
and tried that, but it did not turn out good, so I scrapped it.
I looked at the design of the Semcycle giraffe and patterned mine after that. A
few of the mistakes I made-
The fork where the axle actually bolts onto needs to be reinforced and extra
thick. I also had to redo this.
Unless you are a real engineer, I would suggest just buying a giraffe. I got all
the steel for mine for free, and had a friend do the welding for me, but it
still ended up costing me about $75 US (seat, new wheel, tire, paint, asst.
parts). It looks great and I can ride it O.K., but I just save it for parades-
it’s 6 1/2 '.
After all that, I found a 5’ giraffe in a bike shop for $50. That is the one I
ride most of the time.
Of course, if you’re determined to build your own, I’m sure you can get plenty
of advice from the pros on the NG.
Buenos Suerte-
----- Original Message ----- From: Camilo Salas K. <bakan@directo.cl> To:
UniChef.com <UniChef@unichef.com> Sent: Sunday, June 18, 2000 5:27 PM Subject:
Re: CokerChef
> > Fortunately, I have 5 more unis in the garage. So I extrapolated the pedals
> > off my Sem, and the seat off my homemade giraffe and took off. What a blast!
> how do you make your homemade giraffe?
> im a unicyclist from the south of Chile, south america, and im looking for
> instructions of a good homemade unicycle but i didnt find info. can you please
> tell me?
> thanks
> Camilo Salas K. Coyhaique XI region Chile.
