Does anyone know which size of spoke wrench you need to fit the stock Coker spoke nipples? If so who makes tools to fit? I believe both Trek and Park make good spoke wrenches which grip on three sides of the nipple (but I don’t know which size it is I need to get!).
Is that right? The gauge numbers I’ve seen for nipples are 80 and
105. Normal spoke gauges range from 13 to 16, but the nipple wrench
size usually depends on manufacturer rather than spoke size.
Tony, if you need a spoke wrench while you’re in Fort Collins, give me
a call. I’m in the phone book.
Actually I thought the Coker nipples were 12 gauge. Checking my records I measured it once at 3.95mm which is 0.1555" and 12 ga is 0.156" so I think that is it.
