Coker seat post?
Hey im making a coker and im not sure what the seatpost tube’s diameter is. Can any one help me?
Re: Coker seat post?
“Making a Coker”? Do tell…
Cokers have a 22mm diameter seatpost, but if you are making your own frame you can make the seatpost diameter be any diameter that is available for unicycle seatposts.
jim
The standard unicycle seatpost is, unfortunately, 22.2mm in diameter and this is what the stock Coker uses. If you are making your own frame it would be wise to consider making the seatpost tube to accommodate a 27.2mm diameter post which is a very common size and has seat rail clamps. You would need a seat rail adapter and then you could do anything you want.
Im not building the components, im using a bedford frame prolly a seatpost from him aswell, im ordering an airfoil rim UDC wide hub, coker spokes, Nimbus X cranks, bullet proof pedals, kh fusion seat, the obvious tire.
