Coker long distance
Hey I’m thinking about entering a 25 mile bicycle ride(not a race) on my coker. What is the softest seat for long distance?
Is this handle actually worth there money or are there better handles?
What size s are best for fast riding?
Hope you can help me.
Thanks in advance.
Check out threads on T7 handles. You will find lots of feedback. I personlly love my T7. I bought it with my N36.
Check out threads on T7 handles. You will find lots of feedback. I personlly love my T7. I bought it with my N36. A homeade air saddle would probable be the most comfortable. I have the an the air saddle option that I bought with my Nimbus36. It is pretty comfortable, but the air bladder tends to slide around a bit until I taped it down some.
Keep in mind that softest may not be the most comfortable. Personally, I use a stock KH freeride saddle with padded cycling shorts, and it works pretty well. (I’ve done 100K on this setup.) I think the best thing to do is try out different saddles and see what works for you.
I like my modded KH air seat
I wrote an article about it in review. Many others will say the KH free ride.
A Kh fusion freeride or Nimbus Gel will do you well for that kind of distance, you deff. want a 36" or a geared 29" wheel. I have the T7 and love it, it really helps with control and seat comfort.
I think the T7’s main advantage is that so much stuff can be attached to it-- I stopped using it because it’s cumbersome if you aren’t using it to that advantage.
Try searching for reviews on the Scott Wallis V-Grip: http://www.wallisdesign.com/HANDLEpics.html
I love my T7, even without it it has helped me alot.
It is very easy to change speeds with it and keep a good steady balance.
