Coker in Black
Paul Wyganowski frame,handle & rear rack
Airfoil rim
105 ga. body spoke nipples
SS spokes(4x)w/#2 brass washers behind the spoke heads
Suzue hub
Miyata bearing holders
125mm steel cranks
Odyssey “triple trap” pedals
Primo double bolt clamp
“Avid” brake
Specialized “pro afterburner” tailight
Carbon Fibre w/ air pillow saddle (Roach & Gemcrest)
Zefal “paris” trunk bag
Specialized “sport” computer
Thumb shifter
mounting plugs
upside down mounted Nite Rider Light
grips,end plugs,water bottle cage & a bell
So far I’ve ridden this beauty for a week (250+ miles)
The wheel is light, but the seat weighs a ton :slight_smile:
I weighed the uni at 20 lbs with the handle & rear
rack. It seemed light. Since adding all the other
stuff, it now weighs about 25 to 32 lbs depending on
how much is in the bag.
I love this setup. I did chop off some of the seat
tube in order to lower the handle (long arms). I also
filed down the seam (weld) on the rim a little. There
is still a small “bump” there with the brake pads
close to the rim. It’s easy enough to tune out
though. The ride feels great…such a “clean”
feeling under my feet.
-Mark
another pic
ditto
last pic
Never mind Erin’s ‘quad gallery’ I think she needs to start up a ‘package gallery’!
That’s quite a beast you’ve got there! (the Coker, you perverts)
WOW!
That sure is one cool Coker!
:smiley:
Joe,
WOW! looks really cool, but doesnt the bag on the back get in the way when you are freemounting it?
No, not at all. It did take a while to get used to freemounting with all that weight attached to the seat:)
