This xmas I got myself a Coker Big On e with the Pi bar. I added some tektro v brakes, eaton bar wrap, and SKS fender.
Anyone reading this right now that is on the fence about buying a 36 I urge to you just get one! The speed is unreal!
Frame
The build quality on the Coker is good. Its not perfect by any means. All the parts lined up well and the bearing caps seem well made. The paint is average. Looks great though!
Wheelset
Again the build quality is good. The one issue that I have which is extremely annoying is that the seam on the rim protrudes. While I’m braking it catches and throws me off balance occasionally. I’m going to try to see if I can true the wheel or sand the seam down. This is my one main issue, small but annoying.
Cranks
Eh, they are cranks. lol They aren’t the prettiest. Ill probably upgrade to nimbus venture cranks.
Pedals
Im not too sure what coker thought when they chose these pedals but I want some of whatever they were smoking when they decided this. They only have pins on 1 side and the other side is super slick. I will definitely be purchasing new ones.
Saddle
Its no KH freeride, but its not bad. With a little cutting I think this seat has alot of potential!
SKS Fender
Well its a fender. It keeps my butt dry. Adjustable mounting strap that can fit all my unis. 2 way adjustability to fit the curvature of the wheel. It was under 30$ so I really can’t complain, I would recommend this to anyone interested in keeping their butt dry.
Pi Bar
It is a little short, but it still feel really natural. I wrapped the bars in Eaton handlebar wrap and that made it much more comfortable to hold on to. The bar creates so much stability at speed its unreal! Turning becomes harder while holding the bar but all you have to do is lean up and let go for tighter turns. I would definitely recommend this to anyone with a 36. Plus is got a sexy stem that bolts to the seat post.
Tire
The XLR Ribbed tire is quite terrifying on snow/grit. I really haven’t had a problem with it though. I am just careful of my lines. It is great on the pavement, super smooth and fast!
Overall
I love this thing!
