Cobalt Owners - Update your OpenSSH
Get the latest update here:
CERT Advisory CA-2002-18 OpenSSH Vulnerabilities in Challenge Response
Handling
Original release date: June 26, 2002
Last revised: –
Source: CERT/CC
A complete revision history can be found at the end of this file.
Systems Affected
  • OpenSSH versions 2.3.1p1 through 3.3
Overview
There are two related vulnerabilities in the challenge
response
handling code in OpenSSH versions 2.3.1p1 through 3.3. They may
allow
a remote intruder to execute arbitrary code as the user running
sshd
(often root). The first vulnerability affects OpenSSH versions
2.9.9
through 3.3 that have the challenge response option enabled and
that
use SKEY or BSD_AUTH authentication. The second vulnerability
affects
PAM modules using interactive keyboard authentication in
OpenSSH
versions 2.3.1p1 through 3.3, regardless of the challenge
response
option setting. Additionally, a number of other possible
security
problems have been corrected in OpenSSH version 3.4.
I. Description
Two related vulnerabilities have been found in the handling
of
challenge responses in OpenSSH.
The first vulnerability is an integer overflow in the handling of
the
number of responses received during challenge response
authentication.
If the challenge response configuration option is set to yes and
the
system is using SKEY or BSD_AUTH authentication then a remote
intruder
may be able to exploit the vulnerability to execute arbitrary
code.
This vulnerability is present in versions of OpenSSH 2.9.9
through
3.3. An exploit for this vulnerability is reported to exist.
This
vulnerability is partially described in a recent ISS security
advisory
available at
http://bvlive01.iss.net/issEn/delivery/xforce/alertdetail.jsp?oid=20584
The second vulnerability is a buffer overflow involving the number
of
authentication.
Regardless of the setting of the challenge response
configuration
option, systems using PAM modules that use interactive
keyboard
authentication (PAMAuthenticationViaKbdInt), may be vulnerable to
the
remote execution of code. At this time, it is not known if
this
vulnerability is exploitable. Both vulnerabilities are corrected
by
the patches in a recent OpenSSH security advisory available from
http://www.openssh.com/txt/preauth.adv
Both vulnerabilities exploit features present only in version 2 of
the
SSH protocol.
Vulnerability Note VU#369347 lists the vendors we contacted about
this
vulnerability. The vulnerability note is available from
II. Impact
A remote attacker can execute code with the privileges of the
user
running the sshd (often root). These vulnerabilities may also be
used
to cause a denial-of-service condition.
III. Solution
Upgrade to OpenSSH version 3.4
These vulnerabilities are eliminated by upgrading to OpenSSH
version
3.4, which is available from the OpenSSH web site at
OpenSSH version 3.4 will correct several other software defects
with
potential security implications not described in this advisory.
Apply a patch from your vendor
A patch for this problem is included in the OpenSSH advisory at
This patch may be manually installed with minor changes to
correct
these vulnerabilities in all affected versions of OpenSSH. Please
note
that applying the patches described in the OpenSSH advisory does
not
correct the other software defects with potential
security
If your vendor has provided a patch to correct these
vulnerabilities,
you may want to apply their patch rather than upgrading your
version
of sshd. System administrators may want to confirm whether
their
vendor’s patch includes the other possible vulnerabilities
corrected
in OpenSSH 3.4. More information about vendor-specific patches can
be
found in the vendor section of this document. Because the
publication
of this advisory was unexpectedly accelerated, statements from all
of
the affected vendors were not available at publication time. We
will
update this document as vendors provide additional information.
Disable SSH protocol version 2
Since both vulnerabilities are present only in protocol version
2
features, disabling version 2 of the protocol will prevent
both
vulnerabilities from being exploited. Typically, this is
accomplished
by adding the following line to /etc/ssh/sshd_config:
Protocol 1
This option may set to “2,1” by default. System administrators
should
be aware that disabling protocol version 2 may prevent the sshd
daemon
from accepting connections in certain configurations. Applying one
or
both of the configuration changes described below may be a
less
disruptive workaround for this problem.
Disable challenge response authentication
For OpenSSH versions greater than 2.9, system administrators
can
disable the vulnerable portion of the code by setting
the
“ChallengeResponseAuthentication” configuration option to “no”
in
their sshd configuration file. Typically, this is accomplished
by
ChallengeResponseAuthentication no
This option may be enabled (set to “yes”) by default. This
workaround
should prevent the first vulnerability from being exploited if SKEY
or
BSD_AUTH authentication is used. It will not prevent the
possible
exploitation of the vulnerability via PAM interactive
keyboard
authentication.
Disable PAM authentication via interactive keyboard
can
disable the vulnerable portion of the code affecting the
PAM
authentication issue by setting the
“PAMAuthenticationViaKbdInt”
configuration option to “no” in their sshd configuration
file.
Typically, this is accomplished by adding the following line
to
PAMAuthenticationViaKbdInt no
This option may be disabled (set to “no”) by default. This
workaround
should prevent the second vulnerability from being exploited if
PAM
interactive keyboard authentication is used. It will not prevent
the
possible exploitation of the vulnerability via SKEY or
BSD_AUTH
authentication.
Disable both options in older versions of OpenSSH
For OpenSSH versions between 2.3.1p1 and 2.9, system
adminstrators
will instead need to set the following options in their
ssh
configuration file:
KbdInteractiveAuthentication no
Setting both of these options is believed to prevent the
exploitation
of the vulnerabilities regardless of which authentication
mechanisms
are used.
Use privilege separation to minimize impact
System administrators running OpenSSH versions 3.2 or 3.3 may be
able
to reduce the impact of this vulnerability by enabling
the
“UsePrivilegeSeparation” configuration option in their
sshd
configuration file. Typically, this is accomplished by adding
the
UsePrivilegeSeparation yes
This workaround does not prevent these vulnerabilities from
being
exploited, however due to the privilege separation mechanism,
the
intruder may be limited to a constrained chroot environment
with
restricted privileges. This workaround will not prevent
these
vulnerabilities from creating a denial-of-service condition. Not
all
operating system vendors have implemented the privilege
separation
code, and on some operating systems, it may limit the functionality
of
OpenSSH. System administrators are encouraged to carefully review
the
implications of using the workaround in their environment, and use
a
more comprehensive solution if one is available. The use of
privilege
separation to limit the impact of future vulnerabilities
is
encouraged.
Appendix A. - Vendor Information
This appendix contains information provided by vendors for
this
advisory. As vendors report new information to the CERT/CC, we
will
update this section and note the changes in our revision history. If
a
particular vendor is not listed below, we have not received
their
comments.
Compaq Computer Corporation
SOURCE: Compaq Computer Corporation, a wholly-owned subsidiary
of
Hewlett-Packard Company and Hewlett-Packard Company HP
Services.
Software Security Response Team
x-ref:SSRT2263
At the time of writing this document, Compaq is
currently
investigating the potential impact to HP Tru64 UNIX,
commercial
version of SSH for V5.1a.
As further information becomes available notice will be provided
of
the completion/availability of any necessary patches through
standard
product and security bulletin announcements and be available from
your
normal HP Services support channel.
Caldera
Caldera OpenLinux OpenSSH has neither the S/KEY nor BSD Auth
features
compiled in, so it is not vulnerable to the
Challenge/Response
vulnerability. We do have the ChallengeResponseAuthentication
option
on by default, however, so to be safe, we recommend that the option
be
disabled in the sshd_config file.
In addition, the sshd_config PAMAuthenticationViaKbdInt option is
off
by default, so OpenLinux is not vulnerable to the other
alleged
vulnerability in a default configuration, either. However,
Caldera
recommends that this option be disabled if it has been enabled by
the
system administrator.
Cray, Inc.
Cray, Inc. has found the OpenSSH released in Cray Open Software 3.0
to
be vulnerable. Please see Field Notice 5105 and spr 722588 for
fix
information.
Debian
Debian 2.2 (the current stable release) is not affected by
these
problems. The current versions of our “testing” distribution,
to
become Debian 3.0, and our “unstable” distribution, are both
affected
by default.
We recommend that users be certain that both:
and
are present and uncommented in /etc/ssh/sshd_config (and that
the
server is restarted). Also, we recommend the use of version 3.3p1,
now
available from security.debian.org (DSA-134). Stable users do not
need
to upgrade and may wish to wait until the packages have
received
better testing.
We intend to provide 3.4p1 packages in the near future.
Engarde
Guardian Digital ships OpenSSH in all versions of EnGarde
Secure
Linux. Version 3.3p1 was introduced by ESA-20020625-015 on June
25,
2002. This update introduces privilege separation. All users
are
strongly urged to upgrade to this version as soon as possible.
An upgrade to version 3.4p1 (which properly fixes the bugs) will
be
made available sometime in the next few days.
Hewlett-Packard provides a version of SSH: HP-UX Secure
Shell
(T1471AA) for HP-UX versions 11.00 and 11i. We are investigating
to
determine whether this product is vulnerable.
IBM Corporation
IBM’s AIX operating system does not ship with OpenSSH;
however,
OpenSSH is available for installation on AIX via the Linux
Affinity
Toolkit. The version included on the CD containing the Toolkit
is
vulnerable to the latest discovered vulnerability discussed here as
is
the version of OpenSSH available for downloading from the IBM
Linux
Affinity website. Anyone running this version is advised to follow
the
recommendations above to limit their vulnerability.
We working with the changes for version 3.4 and will have a
new
package availble for download as soon as possible. When available
the
new packages can be downloaded from:
http://www6.software.ibm.com/dl/aixtbx/aixtbx-p
This site contains Linux Affinity applications
containing
cryptographic algorithms, and new users of this site are asked
to
register first.
Lotus
Lotus products are not vulnerable to this problem.
Mandrake Software
MandrakeSoft released OpenSSH 3.3p1 in updates Monday night
to
mitigate this vulnerability. Updates to OpenSSH 3.4p1 will
be
available for download later this week.
Microsoft Corporation
Microsoft products are not affected by the issues detailed in
this
advisory.
Network Appliance
NetApp systems are not vulnerable to this problem.
OpenBSD
See http://www.openbsd.org/errata.html#sshd
OpenSSH
See http://www.openssh.com/txt/preauth.adv
Process Software
MultiNet, TCPware, and SSH for OpenVMS are not affected by
the
problems outlined in this advisory.
RedHat Inc.
Red Hat Linux versions 7, 7.1, 7.2 and 7.3 as well as Red Hat
Linux
Advanced Server version 2.1 ship with OpenSSH. The Red Hat
Linux
OpenSSH packages were not compiled with either BSD_AUTH or
SKEY
enabled, therefore in order to be vulnerable to this issue a
user
would need to have enabled the configuration
option
“PAMAuthenticationViaKbdInt” in their sshd configuration file
(the
default is disabled).
We are continuing to investigate this vulnerability and will
release
updated packages where appropriate.
SGI
At this time, SGI does not ship OpenSSH as a part of IRIX.
The OpenSSH privilege separation code mostly works with IRIX, but
it
uses a flag to mmap that isn’t in IRIX (MAP_ANON) for compression
so
you can’t have both on at the same time. IRIX doesn’t ship with PAM
so
a lot of the PAM issues aren’t issues for us.
The CERT/CC thanks Theo de Raadt and Markus Friedl of the
OpenSSH
project for their technical assistance in producing this advisory.
Author: Cory F. Cohen
This document is available from:
http://www.cert.org/advisories/CA-2002-18.html
CERT/CC Contact Information
Email: cert@cert.org
Phone: +1 412-268-7090 (24-hour hotline)
Fax: +1 412-268-6989
Postal address:
CERT Coordination Center
Software Engineering Institute
Carnegie Mellon University
Pittsburgh PA 15213-3890
U.S.A.
CERT/CC personnel answer the hotline 08:00-17:00 EST(GMT-5)
EDT(GMT-4) Monday through Friday; they are on call for
emergencies
during other hours, on U.S. holidays, and on weekends.
Using encryption
We strongly urge you to encrypt sensitive information sent by
email.
Our public PGP key is available from
http://www.cert.org/CERT_PGP.key
If you prefer to use DES, please call the CERT hotline for
more
information.
Getting security information
CERT publications and other security information are available
from
our web site
To subscribe to the CERT mailing list for advisories and
bulletins,
send email to majordomo@cert.org. Please include in the body of
your
message
subscribe cert-advisory
  • “CERT” and “CERT Coordination Center” are registered in the
    U.S.
    Patent and Trademark Office.
NO WARRANTY
Any material furnished by Carnegie Mellon University and the
Software
Engineering Institute is furnished on an “as is” basis.
Carnegie
Mellon University makes no warranties of any kind, either expressed
or
implied as to any matter including, but not limited to, warranty
of
fitness for a particular purpose or merchantability, exclusivity
or
results obtained from use of the material. Carnegie Mellon
University
does not make any warranty of any kind with respect to freedom
from
patent, trademark, or copyright infringement.
Conditions for use, disclaimers, and sponsorship information
Copyright 2002 Carnegie Mellon University.
Revision History
June 26, 2002: Initial release
Peter N. Go - mailto:peter@icthus.net
http://CGI-City.net http://ArticleCity.com
http://ZenSearch.com http://BannerBuild.com
http://RegisterGuy.com http://BudgetWebHost.com
http://NewsCuts.com http://FreeMailWeb.com
2,500 Qualified Visitors to your website for only $25.
http://www.icthus.net/pay-per-click/
Accept Credit Cards Online. Run An Affiliate Program.
http://www.icthus.net/cgi-city/clickbank.html
Re: Cobalt Owners - Update your OpenSSH
> http://pkgmaster.com/i386/RaQ3-RaQ4-OpenSSH-3.4p1-1.pkg
> Handling
Or you can change the following in sshd_conf (/etc/ssh/sshd_config on my
puter)
ChallengeResponseAuthentication yes
to
make sure to remove the # if it’s there.
The new package above is not “fixed” I would wait till it’s fixed before
updating. Disableing ChallengeResponseAuthentication will not cause you any
problems as almost no one ever uses it.
John R. Marshall - Web Developer
JRM Studios - http://www.jrmstudios.com
The Hotrodding Network - http://www.hotrodding.net
> puter)
> to
Also set
(Just read an update on bugtraq)
“John R. Marshall” wrote:
Does this require a reboot?
Thanks, btw.
> Thanks, btw.
Nope it’s linux :wink:
just stop/start sshd
Spent the last 2 days updating some of my clients’ Cobalt RaQs - was
thinking in terms of Cobalt PKGs :slight_smile:
