Choosing a 20" for skill practice
Yeah, I think some 125mm cranks might be in order at some point. I have a spare set somewhere. They’re not really up to much abuse (they’re the old Quax silvers) but they’ll get me started.
I’ll stick with the 138mm for now since they’re on there. My reference point is 125mm on my 36er, so anything on the 20" is going to feel very light anyway.
Instead of adapting your setup to accommodate your customary riding style (i.e. shortening your cranks), I suggest you keep the 138mm cranks on for a while and try to adapt your riding style to the trials setup. If this is completely new to you, if you’re struggling, that is a good thing. The twitch-iness of the setup will quicken your reflexes. Practice riding up impossibly steep hills with the 138mm cranks. Practice riding up a curb without unweighting (warning: even at high tire pressure you can hit bottom). Practice one footed still stands. Some new mounts may get easier with the longer cranks. Try to make the longer cranks the “right” cranks for the things you’re practicing. Otherwise you will be, to some extent, trying to emulate the larger wheel technique on the smaller wheel. Just my two cents…
I think you’re right. I’ve left the 138mm cranks on and they don’t bother me any more.
Today I landed a wrong-footed freemount. Took me a few days. Baby steps…
I recently got a Athmos as well and swapped to 125s that I had. The seat is not very good compared to my Nimbus Unis. I haven’t put too much time on it yet but the 125s feel good and make it easier to do tight circle without fear of pedalstrike or making huge circles with my legs as i try to pedal quickly.
For reference I currently have
125 on the Athmos (may go back to 138 once I get the strength for bigger hopping tricks)
125 on my Freestyle 20"
138 on my Road 29" with Brake
150 on my 24" Nimbus Oracle MUNI with Brake
The seats on those unis aren’t designed to be comfortable to sit on, but to be comfortable to grip in seat out for tricks.
If you want to help @elpuebloUNIdo out, maybe you can comment here to offer another perspective on the difference between 19" and 20" for riding.
Apologies if my contribution makes you ask for more, however, I did continue with info pertaining to the crank size discussion which was already in this thread. Thanks!
Edit: Is this even the same thread as what you reference 19" vs. 20" ???
I must have worded that in a confusing way. It’s not that I found your contribution lacking, on the contrary I think it’s a good addition to the discussion of crank lengths here.
But I randomly remembered that in that thread I linked (it’s indeed a different thread to this one), a question was asked that you would now be in a great position to answer, since you now have experience on very similar setups with the only difference being a 19" tire vs. a 20" wheel. So all I wanted is for you to see that question, so that if you thought you have anything to add to that, you could.
Sorry for the confusion!
