Basically i’m moving out of the country and don’t have the space to keep these spares around. Most have been used quite harshly, but I will sell cheap
If you combine stuff I’ll give you a discount. Postage will be what it costs me so expect £1-3 depending on what you get. If you want international shipping then you work it out estimating the weight and tell me
Koxx 140mm (reinforced & nearly ISIS) cranks - very slight bend on the left one. Perfeect for trials or even to try out different crank length on a muni. They fit on my 07 KH moment hub and K1 reinforced hub. - £8 - http://madeo.co.uk/files/fourth.jpg, http://madeo.co.uk/files/sixth.jpg
Gusset Magnesium bear traps - Can’t remember what they are exactly, worn but still spinning fine. 234g per pedal - £5 -http://madeo.co.uk/files/fith.jpg
Enough to make a seat. Ripped Koxx devil foam (wouldnt recommend using), KH street fusion gel foam (slightly ripped but perfect if you want to thin it), Old style KH saddle with intact reinforcement plate, and slightly ripped in the corner KH fusion street cover. (notice you’ll be missing one hexx screw at the back and both bumpers) - £5 - http://madeo.co.uk/files/second.jpg
CRMO seatpost 27.2 - cut badly (by Dan, not me). Hardly ridden. - £5 - http://madeo.co.uk/files/third.jpg
Koxx Black Seatpost clamp (fully functionall, just scratched a little) - £1 - http://madeo.co.uk/files/first.jpg
Sister Thread : http://unicycle.org.uk/forum/viewtopic.php?f=9&t=413
If you want more photos just ask. I can give you better res ones
