Changing the Wheel Size.
TOM@SLACVM.SLAC.STANFORD.EDU writes:
>From a twenty-four incher to a twenty. Funny when I asked for the phone no.
>for Semcycle, this is the question I wanted to ask. Sem’s dad says on the
>“Sem” which is what I have, not the XL, can be changed to the twenty inch
>wheel and tire. The only hard part is to press out the bearings. The fork will
>also have more clearance. I’ve decided not to do it since I couldn’t rapidly
>swap wheels. -tom
Bearings aren’t that expensive–why not just leave a set of bearings, cranks &
pedals on each axle? Then you’d only have to mess with the bolts on the bearing
clamps to quickly & easily change wheels.
Dennis Kathrens
