Can you use stock Coker spokes on Airfoil rim and UDC extra wide hub?
Or is a different length spoke needed?
I believe that is what you get when you order an Airfoil wheelset from UDC. The UDC superwide hub’s spoke holes are drilled to accept the stock Coker spokes.
I didn’t know if the double walled rim and the width of the hub would change the spoke length need.
Does this info help?
http://www.unicyclist.com/forums/showthread.php?s=&threadid=38844&highlight=coker+spokes
Tim and I re-built his coker wheel with a superwide hub and the stock coker spokes and they worked fine. His rim was the re-manufactured alloy rim that had the regular wide hub in it.
You mean the brushed steel rim that looks like aluminum?
ie - “The Delorean Rim”
Yea, that one.
Haha…“The Delorean Rim”
