NNNate
August 11, 2015, 5:09pm
1
Hello, I was wondering if you could install a disk brake on any unicycle. This is because I really want a disk brake but I don’t want to spend 650$ on a Nimbus Oracle. Instead, I was wondering if I could install a disk brake on the nimbus muni here:
Thanks,
Nate
Reeny
August 11, 2015, 5:19pm
2
There is a disc ready one available for $40 more with the bearing clamp, and the disc compatible hub
http://www.unicycle.com/unicycles/mountain-unicycle/nimbus-26-inch-mountain-unicycle.html
The disc ready version would be a better bet
$30 bearing clamp + new hub + wheel rebuild will end up being much more expensive than $40.
You can also go with the D-brake adaptor and KH Spirit cranks. But then again, KH cranks aren’t cheap.
Or buy a d brake and some spirit cranks and add whichever disc brake you were thinking.
Edit: Flans beat me to it.
NNNate
August 11, 2015, 8:04pm
5
What adapter do I use for the nimbus frame?
jaco_flans:
but they are so good! : ]
