buying a unicycle
darwin@dorite.use.com (Darwin Teague) wrote:
>I called around to the bike shops in the area without much luck. About 4 or 5
>shops can order them, the problem is, none of them know what brands they are!
>How do they expect someone to make up one’s mind without knowing that?
            If they don't know what brand, I would simply tell them what you
            wrote above. How are you supposed to decide, and would you
            expect anyone to buy a bicycle under those same conditions?
            Realistically, though, most of them would probably be nearly the
            same. Most of the unicycles you can currently buy in bike shops
            in the USA all originate in the same factory in Taiwan. Some are
            better than others, depending on saddle, pedals, and bearing
            arrangement.
>The prices are pretty close - $90 to $111 for 24 inch ones. I’m not looking for
>any competition stuff, just something to play on. The one name I heard was
>“Timberland” or something similar to that.
    I've not heard of Timberland, and would be curious to know more. I'm
    willing to bet it's another Taiwan uni. with a Timberland sticker.
>Could anyone fill me in on the brands that are currently available?( I have the
>FAQ, so what I’m really looking for is what shops would probably be able to get
>easily). Would a uni in that price range be worth buying?
    With access to the FAQ, and all of us, why buy from a bike shop? Order
    direct, remove the middleman, and *maybe* save a few bucks. In the price
    range you mentioned, you can get a decent Taiwan type.
>One shop has a used one for $65, I think I’ll go look at that and see what it
>looks like. The guy claims it’s well built.
    The used cycle might be a Schwinn, which is still the most common "used"
    unicycle on the market. Grab it. You can still get parts from the
    Unicycle Factory, and it is stronger than almost everything.
>FWIW, there is virtually NO unicycle presence in this area. I knew 2 guys that
>had unis when I had mine, and one kid that had one when I first got mine. Those
>are the only ones I’ve ever seen in this area. I haven’t had one for at least
>15 years, probably closer to 20…
    I know you've told us before, but what is "this area?" The fewer
    unicyclists in your local area, the more likely you will be able to find
    a Schwinn, or even a Miyata, languishing in a nearby bike shop.
>Dishheads, dishheads, roly poly dishheads!
    As long as I'm giving you free advice, please tell us what your
    sig. means.
sling@io.org (Sling) wrote:
>A simple word of advice to anyone wanting to buy a unicycle:
>Do NOT buy a unicycle from a bicycle shop. Do NOT, do NOT, do NOT!!!
>You will simply be throwing your money away. All unicycles sold in bike stores
>are made by bicycle manufacturers who don’t know the first thing about building
>a solid unicycle.
    I beg to differ. Miyata makes excellent bicycles *and* unicycles (for
    the lucky people who can get them). Schwinn made a good, strong,
    serviceable unicycle, and the best ever-giraffe, in my opinion.
>Even if you only want it for a little recreation, buy a decent unicycle.
>I recommend Semcycle, but miyata and some others are good too. Don’t buy
>a norco!!!
    Strong words, to which many of us have already responded. For you
    non-Canadians, a Norco is another version of the generic Taiwan cycle.
    They aren't that bad, but anyone with access to this mailing list can do
    better. BTW, as far as I can tell, the frames on the Semcycle XL
    unicycles are from Taiwan as well.
    Sling did not mention the worst unicycles in the world, which are
    the ones appearing in department store and physical education
    catalogs. These pieces of junk are made by companies in the juvenile
    cycle business (tricycles and the like), and most will not support
    even the weight of the riders they are built for without
    complaining. Buyer beware!
    What sad times these are for unicycle buyers in the USA. Schwinn is no
    longer around. Miyata, if you're in-the-know, can be obtained, but at a
    high price. Semcycles are very good, but are not found in bike shops, so
    the general public can't get them. What can we do to change this?
    The only thing we can do is get more people riding, so more people are
    buying them, so the manufacturers see that it's worth their time. Also,
    to get as much press and good publicity for unicycling and unicyclists
    that we possibly can. Like having your picture in the paper? It's not
    hard. I intend to get the local papers here (Sacramento, CA) to do some
    kind of story about me when I'm ready with new promotional materials for
    my show. I'll let you know how it turns out.
John Foss, the Uni-Cyclone unicycle@aol.com
Re: buying a unicycle
i: >One shop has a used one for $65, I think I’ll go look at that and see what it[/i]
i: >looks like. The guy claims it’s well built.[/i]
i: The used cycle might be a Schwinn, which is still the most common “used”[/i]
i: unicycle on the market. Grab it. You can still get parts from the[/i]
i: Unicycle Factory, and it is stronger than almost everything.[/i]
The sticker on it says “Quentin”. I’ll be seeing a friend that still has a
Schwinn on the 25th. Also, I have a Semcycle catalog on the way. I had a Schwinn
once and sold it (sob, sob).
i: >FWIW, there is virtually NO unicycle presence in this area. I knew 2 guys[/i]
i: >that had unis when I had mine, and one kid that had one when I first got[/i]
i: >mine. Those are the only ones I’ve ever seen in this area. I haven’t had one[/i]
i: >for at least 15 years, probably closer to 20…[/i]
i: I know you’ve told us before, but what is “this area?” The fewer[/i]
i: unicyclists in your local area, the more likely you will be able to find[/i]
i: a Schwinn, or even a Miyata, languishing in a nearby bike shop.[/i]
Anderson, Indiana. There are no used Scwinn’s in the area, but there IS a
Schwinn penny farthing here for only $999! What a deal!!
i: >Dishheads, dishheads, roly poly dishheads![/i]
i: --------------------------------------------------------------------------[/i]
i: As long as I’m giving you free advice, please tell us what your sig.[/i]
i: means.[/i]
It’s a play on words. People hooked on satellite TV (like me) are called
Dishheads. There was a song called “Fishheads” and this is a line from the song.
(BTW, there are 2 more lines to my sig, which are deemed inappropriate for this
mailing list so I delete them when I post here).
