Broken, Bent, or Cheap steel uni frame
I’m building a 32, and I need a donor frame for the bearing holders. I’m not too picky. Pressed, forged, painted, chromed doesn’t matter. Even the size of the frame from 12 to 36 would be okay. Let me know if you have anything.
Thanks,
Jerry
I have a 16" frame at home I can give you, I’ll just make sure I have the bearing caps though. They’re pressed bearing holders, you might even be able to use the neck if you dont have any, it’s for a 22.2mm seatpost.
The frame was given to me because it wasn’t good, it doesn’t fit a wheel that is true haha!
PM me we can arrange shipping!
Frame is on the way. Closing thread.
