Re: British Unicycle Convention RIP ??
Text item:
Jonathan Marshall wrote about combining the British Unicycle Convention with the
European Juggling Convention.
The EJC is taking place in Edingurgh, Scotland August 3-8. I just wanted to
point out that this convention starts the day after UNICON IX ends. Hint hint,
nudge nudge.
If an actual unicycle convention will be there, it’s enough to make me take even
more days off from work to be there. In other words, if people choose to do it
that way, I will do my best to be there.
Sorry, can’t help with the organization, I’m already working on a
convention or two…
John Foss reply to: unifoss@calweb.com http://www.calweb.com/~unifoss
______________________________ Reply Separator _________________________________
Subject: British Unicycle Convention RIP ?? Author:
unicycling-owner@icicle.winternet.com at SMTPGATE Date: 2/10/98 7:36 PM
At last years British Unicycle Convention it was decided that this year the
convention would be organised by Hackney and it would probably be sometime in
May. It now looks like this will not happen. Some of the Hackney hockey team
have moved away recently and in particular James Bentley who was leading the
organisation has just got a new job in Manchester.
I was at a Juggling convention in York a couple of weeks ago and met up with the
organisers of this years British and Eupopean Juggling Conventions and there was
a suggestion that we might attach ourselves to one of those rather than trying
to set something up specifically for Unis. The BJC is a bit close (over Easter
weekend) but the EJC ( in Edinburgh in 3rd to 8th August ) is quite an
interesting suggestion as they have booked the whole of Meadowbank stadium for a
week so there would be a good track as well as an area for hockey etc. and Roger
Davies and the DCJ are already organising a Muni event for them.
Does anyone else have any other suggestions?
Do you want a separate convention?
Do you want to organise it?
Do you care?
If you have been to previous British Conventions and didn’t go last year, why
not? Was there something about them you didn’t like? In that case what would
make you want to go again?
All comments welcome… Well, nearly all.
I personally wouldn’t like to see it die out again but numbers have been
dropping each year and we need to get some more new people involved and maybe
going back with one of the juggling conventions is a possible way of doing that.
Is there anybody out there… except,
Jon ?
Jonathan Marshall /| O O/ /|\ /| /|\ _/| / |\ LUNIs Unicycle Hockey Club
/| >>\ << |\ / E-mail rocket@jbmarshl.demon.co.uk /| 0 _ o 0 |_/
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: Jonathan Marshall <rocket@jbmarshl.demon.co.uk> Precedence: bulk
Sender: owner-unicycling@winternet.com Xref: paladin.american.edu
rec.sport.unicycling:5033 Lines: 47 X-Newsreader: Turnpike (32) Version 3.05
<u90ohPHXOoeocp7xOndubd3KpE> MIME-Version: 1.0 X-NNTP-Posting-Host:
jbmarshl.demon.co.uk [194.222.5.164] NNTP-Posting-Host: jbmarshl.demon.co.uk
Message-ID: <DFGkyFACxK40EwoY@jbmarshl.demon.co.uk> Organization: UNICON VIII
Date: Tue, 10 Feb 1998 19:36:34 +0000 Subject: British Unicycle Convention RIP
?? Newsgroups: rec.sport.unicycling From: Jonathan Marshall
<rocket@jbmarshl.demon.co.uk> Path:
auvm!paladin.american.edu!cpk-news-feed4.bbnplanet.com!
cpk-news-feed1.bbnplanet.com!cpk-news-hub1.bbnplanet.com!news.bbnplanet.com!wo
odstock.news.demon.net!demon!news.demon.co.uk!demon!jbmarshl.demon.co.uk!rocket
To: UNICYCLING@winternet.com Received: from AUVM.AMERICAN.EDU (NJE origin
NETNEWS@AUVM) by AUVM.AMERICAN.EDU (LMail V1.2a/1.8a) with BSMTP id 0306; Tue,
10 Feb 1998 18:26:21 -0500 Received: from AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU
(IBM VM SMTP V2R2) with BSMTP id 5618; Tue, 10 Feb 98 18:26:21 EST Received:
from auvm.american.edu(147.9.1.2) by icicle.winternet.com via smap (V2 .0) id
xma002594; Tue, 10 Feb 98 17:30:26 -0600 Received: (from adm@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id RAA02742 for <UNICYCLING@WINTERNET.COM>;
Tue, 10 Feb 1998 17:31:21 -0600 (CST) X-Authentication-Warning:
icicle.winternet.com: server set sender to owner-unicy cling using -f Received:
(from server@localhost) by icicle.winternet.com (8.8.8/8.8.8) id RAA02865 for
unicycling-outgoing; Tue, 10 Feb 1998 17:32:04 -0600 (CST) Received: from
icicle.winternet.com (icicle.winternet.com [198.174.169.13]) by
thalia.fm.intel.com (8.8.6/8.8.5) with ESMTP id QAA06988 for
<JohnX_Foss@ccm.fm.intel.com>; Tue, 10 Feb 1998 16:13:14 -0800 (PST) Received:
from thalia.fm.intel.com (thalia.fm.intel.com [132.233.247.11]) by fmm
ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id QAA21717 for <JohnX_Foss@ccm.fm.int
el.com>; Tue, 10 Feb 1998 16:10:07 -0800 (PST) Return-Path:
