We don’t use Torkers here in Toronto, Canada, but I have a web page with
numerous tires both in 20" and 24", with actual tire widths, if available.
The published widths from many tire manufacturers are a little over
inflated. When you get to a fat tire over 2.5" you’ll also need to measure
the height of the tire above the rim to ensure you have enough top
clearance. You’ll need at least 1/2" or rocks/snow/mud will jam in between
the top of your tire and your frame, causing you to an unceremonious
flying forward dismount.
You don’t say if you have a 20", 24" or 26", so the answer depends on your
question…
Wayne van Wijk wrote: > > What is the biggest tyre that will comfortably fit on a torker’s > standard rim? > > What is the biggest rim and tyre combination that will comfortably fit? > > (I am too lazy to go and measure the things myself). > > Wayne van Wijk wayne@jester.com.au > > ____________________ > > Visit www.jester.com.au for Entertainment, Workshops and Circus Supplies > ____________________
