Disk Brake? I’ve only seen one set of pictures to do with disk brakes on Muni’s. Any chance you could post some on the Gallery and a description of how you got around the asymmetry problem? Did you use an asymmetric hub or an asymmetric frame. How did you find the clearances between the disk, hub, frame and brake pots? Basically any info would be greatly appreciated.
I used a commercially available front hub and disc brake kit and then had an axle made and mated to it. The rim is laced offset so that the frame is symetrical. I’ve had it for 3 months now with so far no problems. I’ll try to get some photos up this week.
There Are some pictures, I think, on www.Muniac.com . Im not sure where it
is but I think it’s there.
Noel.Holland wrote:
> Gabe wrote:
> > *I lightly sanded the rim at the joint on my old muni for smoother
> > braking with no problems. Now I have a disc brake which is better
> > still. *
> hub or and asymmetric frame. How did you find the clearances between the
> appreciated.
> Noel.Holland - --------------------------------
> Noel.Holland’s Profile: http://www.unicyclist.com/profile/560
> View this thread: http://www.unicyclist.com/thread/17898
> ___________________________________________________________________________
> rec.sport.unicycling mailing list - www.unicycling.org/mailman/listinfo/rsu
