Benifits of handlebars?
I have used the Shadow handle on 29", 26" and 24" unicycles. I first installed the Shadow handle on my 29er. I was hesitant to cut length off the handle, so I started out with the handle at full length. Between that and the rim brake I had installed, I felt I was going to eat pavement at any moment. I became both scared and bored of road riding, converted the 29er to a muni, and shortened the handle.
Around the same time, I installed a KH T-bar on my 26" muni. Eventually I swapped the T-bar and Shadow handle (which ended up on my 26"). I spent a lot of time adjusting / experimenting with both the Shadow Handle and the T-bar. The Shadow Handle is more stiff, which I like. I ended up also installing a Shadow handle on my 24".
I think you’re going to have to play around with the handle before you can really evaluate it. The first time I used a handle, it seemed like a nuisance. Now, I ride virtually 100% of the time with both hands on the bar ends.
Regarding your comment about the tightening bolt: I tighten the heck out of it. Figure out how much torque you can apply without deforming the bolt head. I overdid it and had to replace one of the bolts. But, I could go a long time without having to check tightness (which is a kind of PITA with the Shadow).
Your post didn’t indicate how long the handle was, but I suggest you cut it down to muni length, learn to use it at that length, then later on if you feel like it, buy a longer bar. Also, find something to put on the bar ends to soften the blow of the handle hitting the ground. I use rubber stoppers for lacrosse sticks. They have a nice, cushy end. And tighten the crap out of the bolt.
And regarding whether the seat should angle up or down or not at all, I think there’s no substitute for experimentation.
On a side note, I just installed a Mad4One seat/handle on my 26". I bought it with no adornment. On my first ride, I wore thick bicycle shorts. The seat/handle engaged my sit bones nicely and was fairly comfortable, considering that I was sitting on aluminum bars. I bought the “L” (long) model. It measures the same length as my Shadow setup, though it “feels” longer. As with the Shadow and T-bar, it’s going to take a lot of experimentation to get it “dialed-in”.
slamdance, sorry to hear you injured yourself. I hope you are able to keep riding.
36er choices
Let me complicate your choices further and say that 2 of us here in Birmingham AL have the QX36er and love them. We have had them for a couple of years now. We also loved the price compared to the other choices. Hit me up on PM and I can put you in contact with a US rep on pricing for the QX.
Here is the unicycle link.
http://www.goudurix.com/us/qx-series-36-disc-q-axle-black.html
It also comes in white. The pricing I can get is different than listed on their site.
BTW–We use the KH Tbar handle setup on ours and like that.
Can I interest you in a set of encyclopaedias? You don’t know what you’re missing! :stuck_out_tongue:
Mad4One seat/handle
Hello elpuebloUNIdo, do you think the Mad4one seat/handle would be comfortabel for longer rides, prepared with handlebar tape and a little foam padding on the aluminium tubes.
I have the muni version with padding by Marco and I like it very much and consider buying the long version.
