when i bunny hop and hold on 2 the front of my uni set it bends up? anyone else experienced this ?
I have noticed that my Miyata seat has a lot of flex in it. I am thinking about getting the GB4 Stiffener Plate for it.
http://unicycle.com/shopping/shopexd.asp?id=607
What kind of saddle do you have?
Daniel
my KH seat has a lot of flex in it but i’ve just got used to it. i wonder how much energy im loosing from my hops i expect its quite alot probably half an inch from hop height. im going to get the carbon KH seat when it comes out.
later
Well I bought a GB4 Stiffener Plate in January but I can’t find it. It arrived with my rim and tyre so in all the excitement I think I misplaced it.
Andrew
There are 2 generations of KH seats, soon to be 3 generations a few months from now.
The first ~200 units were made without a metal plate stiffener, which was added and significantly increased rigidity. I think these have all sold, as far as I know, so all seats you get now will have the stiffner.
I am currently waiting for a new prototype from Velo to test out, that should hopefully be even stiffer than the current version. You won’t see this model on the market for quite a few months, though.
Yes there will also be a carbonfibre version but don’t expect it to be cheap!
-Kris
What is the difference between the seats that say Axiom on them and the ones that don’t?
That was the first change, wasn’t it? The earlier ones with the “Axiom” logo are without the metal stiffener plate.
It’s great to have a seat that, as well as being fantastic to start with, is still in development. I’m really happy with my first generation KH seat; if I needed to I’d not hesitate to get another one of those, and any improvements are an extra bonus.
Good job!
Phil
really??
my friend got his KH20 a few months ago and his does not say Axiom., but mine , which I got today, does.
In that case, I may very well be wrong… mine says Axiom on the front and it is without stiffener plate.
Curioser and curiouser…
Phil
what color seat do you have? I have a grey and my friend has a blue.
'Tis a black and grey one…
Phil
Re: bendy seat while buny hopping
What kind of seat did you say you were using?
All the plastic seats bend to some degree or other. Some are quite a bit stiffer than others. My KH seat must have the stiffening plate in it, because it seems very rigid.
Older Miyata seats used to get too flexy, and eventually crack at the side rivets just in front of the seat post. Later models fixed this problem, moving the breakage to the post itself.
The type of riding we’re doing today is well beyond the design parameters of nearly all unicycle seats & posts. The most efficient designs will have the handle directly connected to the seat post (or frame), or be on a rigid (non-plastic) seat.
In the future, I envision lightweight seats that attach to posts that have handles and bumpers on them. So the seat itself can be very light, and not have to handle the stresses of pushing, pulling, or dropping. This should make the seats much cheaper to produce, though the newer type of post will of course be more costly than today’s posts.
Does anybody else find the KH seat handle hard to use and uncomfortable?
Dylan
jbunny hopers in our club complain about
the fabric of the KH seat which gets easily ripped off on surface
I’ve seen a manic jumper ruin a seat in just one day!
what do you do to avoid that?
thanks
bear
getting a new seat anyway
i’m getting a KH velo seat sp hopefully my prob will be solved i have this uni wiht theis sat at www.bikewizard.co.uk
