bearings sizes,please help
screw the small talk
I recently bent my hub and/or cranks im looking for a new hub
is it possible to put 40mm bearings onto the qu_ax hub
if not can some please recomend a decent hub that wont cost
muchacho greenos
you can fit a qu-ax hub ints a nimbus rame
tom did it
i did it!
it works great (well it did before my uni was stolen)(actually it probably still does work great).
i just cut up some rubber from an old bike tube and put it in the bearing holders to even out some of the pressure.
You can also buy one of these to shim it:http://www.unicycle.com/shopping/shopexd.asp?id=735
were trying to go from a 42mm hub to a 40mm frame
O sorry. Didnt catch that:o
