BC wheel
I am interested in making a BC wheel out of an old nimbus wheel set. Is it possible to attach BC plate to a standard ISIS hub?
Thanks!
You don’t use a uni wheel for a BC. You want a bmx front hub with a beefy axle.
I was aware of that but I was wondering if there was another way of doing it.
not that i know of. i built mine from a 25$ wheel from dans bmx
I suppose you could build foot plates that clamp to the bearings, but they would move freely of each other. It’s cheaper and easier to use a bmx wheel.
The hub spindle would be in the way also, since it would be spinning as the wheel moves, you’ll have to put your feet away for the spindle.
Could i use any small bike wheel or does it have to be bmx?
I think it would work.
