When I get on my BC Wheel I can’t stop the tire from rubbing my leg. It is destroying my pants/661s. Does any body have something that helps overcome this problem? Thanks
Pigs
Pigs
It just takes practice, there’s no secret to it. Are you practicing the skate mount?
Whats that?
Pigs
A skate mount is when you have one foot on the plates and then push with the other foot to get going. It’s just like pushing a skateboard.
Practise.
He’d better not be, if your leg is rubbing doing the skate mount there’s some nasty dismount potential with the bc acting as a lever arm and your center of balance a foot away from the hub(especially with low plates).
My guess is that you have a bc with pegs, not plates, and are practicing the “hold onto pole for dear life while attempting to push off” method? That seriously bruised my leg from just the pressure after a few hours of practice. I’ve never had a real issue with the tire rubbing; at one point it was rubbing just enough to be slightly annoying. Just take the 661s off and see if the extra space does anything.
A good bc wheel helps also.
When ever I try to to skate mount it rubs againts my jeans so much I cant get any where. I have plates.
Can you legwrap on a regular uni? The side/side balance shift is very similar.
MMMMMmmmmmmm…
