Hey,
The doc cleared me for riding again and i have been riding alot the past few days, i have some tricks im working on, but i could use some more. Im looking for insperation for tricks and such.
Do any of you people have any ideas on tricks i could try? Not anything too impossible.
Jump high in the air, while in the air kick the bc down so it bounces off the ground then land on it. I don’t think it is impossible but I think it is the closest thing you can do to a crankflip (my plates always spin when I drop it).
If you can do that then I will be supremely amazed.
ntappin:
There are much easyer ways to go at a plateflip, you ride with one of your feet on the top of the plate, then hop and shove down on the plate. The plates spin around about 6 times before you are ready to land on them. But this is still really hard to land, also i dont like air tricks, i like to stick to solid tricks.
Maybe some flatland stuff then?
Yeah thats mostly all i do now, So im open to any flatland tricks.
Hey,
umm you could do a stall on top of a ramp (1/4,1/2 pipe)
or wheelwalk hahah-maybe too impossible?
umm do a 1/2 kickflip
ok im getting too impossible… maybe
hm- idk how good you are but try to catch air in a 1/2 pipe
that would be awesome
skrobo:
I’m steering away from any high airing and big skatepark stuff for now, i dont want to break my arm again.
ok, but im just curious if anyone can wheelwalk a BC?
2ft? No. Somepeople call a footskim wheelwalking, but its not, its a 1fted stillstand with an occasional push to edge your way forward.
skrobo
May 20, 2006, 9:04pm
10
would it be possible if you were going fast tho??
it seems like it, but im not good enough @ it to try it
and i did mean 2ft wheelwalking
i got one…
ride up to a ramp that is not stepp and is flat, go about half way up, roll to a stop, grab tire(to stop), body varial, ride down
hope tha makes sence
skrobo:
The faster the worse, you would frist need to learn to be able to stand up onto of that, its a very small area of ballance.
or
roll to a stop, grab wheel, lift up left foot, swing it over the wheel, switch feet on right plate, unispin/varial out of it
hope that also make sense
how about these:
double half and half- instead just doing 2 180s, do at least 4 or more
backwards tire grab
shifty tire/plate grab
tabletop
backwards half and half: ride backwards do a half and half and then keep going backwards
backwards foot skim
see if you can land the 360 (youll probably get it soon im guessing)
2 handed tire grab- like grab the tire in front of you and behind you
pirouette
pirouette to foot skim
late 180
maybe some kind of idle by doing a foot skim back and forth
Ok thats all i can think for you now (im thinking you might be able to do some of these already)
skate4flip:
how about these:
backwards tire grab
tabletop
backwards foot skim
pirouette
late 180
Iv done almost all of those.
whats a tabletop?
jump up, then bend your legs to make the whell flat like a table, like its sitting on the ground(disregard the tilt from any extensions:axle, plate, etc)
unijesse:
Seems like a good way to turn your lower limbs into meatloaf.
Catboy
May 20, 2006, 10:13pm
19
Shove-it(No handed BC spin while rolling). It can be done.
It has to be executed all in mid air, thats very very hard, its a long way off.
