Balls of Kryptonite
Actual photo, or 'shopped?
If a guy can go down niagra falls in a barrel then i’m sure this is possible :roll_eyes:
Very true juni
It’s very hard to tell depth of this photo, because of the angle and the lighting. It’s hard to tell if it’s real. If it’s shopped they did a good job, and I wan’t to say that it is not photoshopped. But the body angle of the kayaker looks too far forward. Don’t you have to lean back when you shoot falls? Maybe he beefed it…
Agree with Dane. Though anything can be Photoshopped to look like almost anything, I don’t see a reason to disbelieve that shot.
I’m not doing that…
http://www.kayaksession.com/tyler-bradt-waterfall-record-palouse.php
any more questions;)
Don’t you have to bow forward when going over the edge?
Otherwise the tail might be pushed under and you loose control.
This is what I expect from my skiing experiences. You can move your weight back to put less force on the edges and go smoother and faster, but you sacrifice control and if there’s a drop the the skis slip right under you.
i have to change - I believe in the god of gravity!
if gravity would be only physical it would be constant - but it has definitly week days and strong days. that make me believing there must be a god:p;):smiley:
before you drop you lean forword then when falling you lean back.
Hmm interesting. I still say real, but I still can’t tell the degree of difficulty because of the angle. Very strange photo.
