Backwards Unicycling: Progress Report
How far can I go?
Currently, I can reliably ride backwards 100 yards, but it is exhausting because I have to “maintain some weight” on my pedals. I am not quite at skill level, where I can “fully seat” and just lightly pedal, as I can in forward riding.
What do I focus on when riding backwards?
a.) Driving my “down foot” into the ground(as if my pedal was made of rubber and I stretch it down to touch the ground). That goes through my head, but in actuality I am just “holding” pedaling tension through 6 o’clock and slowly releasing at 7 o’clock. In mechanical speak, it would be called “power dwell”. The analogy to forward unicycle riding would be just “keeping weight” as you pedal through.
b.) Keeping my knee’s pointed inwards almost rubbing the saddle. This causes my lateral balance to be compact, so when I need to steer, which is accomplished by “exaggerating” my rhythmic twisting motion, I don’t need to do it so aggressively.
c.) I also look “down”. I definitely do that. The “look at a stationary object behind you” does not work for me. I suspect that works only for a “pure balancer” who can virtually do a standstill and then just slowly incorporates “nice steady pedaling in backwards” like a tightrope walker. I don’t do that. Somehow, I harness the rhythmic turbulence of the backwards pedaling, the straight back, and the upper body twisting to be able to do a smooth pedal by pedal controlled motion. I never just lean back and “go”, and rely on acceleration for stability.
d.) I always count my pedaling in my head 1-2, 1-2 or 1-2-3-4. This is to control acceleration. As soon as you just “let it go” you are will be in trouble. I should not brag about this, but I wear no head protection and I have never fallen down backwards. I always land on my feet walking backwards. I always feel in control, because I never allow myself to “speed up”. I am always just going 1-2 pedals at a time. At a split second, I can stop and rock into an idle to stop my motion.
e.) Finally, I should mention that I do not use any rails or walls. I did this learning forwards, but I always start my backwards riding from an idle. In fact, my standard free mounting is a rockback Idle. I believe that got me 50% on my way to learning to ride backwards. So, I highly recommend anyone trying to ride backwards or even just learning to idle. To “terminate” your reliance on the 3/9 o’clock free mount. Start with down foot near 6 o’clock or 7 or 8 o’clock, rock back and free mount. At the very least, being able to free mount rock back idle will make you “dead zone” proof(because your top foot learns to become active).
3.) How about turning?
I am not perfect in this area. I can turn in a wide area like in a 20 ft “square”. In forward riding, I can turn well by just “varying” pedal force, but prior to that I was “twisting” the unicycle to turn. So, turning in backwards motion I am currently only able to “twist”. Not 100% at twisting, either. It seems to work best when I twist when the “inside” pedal is going down stroke. That is if I an turning right, then I wait for the right pedal to go down then I twist. On the other pedal, I keep straight.
