axle wear on a Swchinn 24" (fwd)
Forwarded message:
> Dear One-wheelers,
> My Schwinn 24" (nick-named ‘the tank’ by some) is now 14 years old. I
> used to use it is my primary vehicle, so it has many miles on
> it. I would be happy to keep it forever, except that the wheel has slowly
> come to wobble, currently by slightly more than 0.5" at the rim. In spite
> of having consulted many people, I do not have a clear explanation for
> this problem, and hence don’t know if it can be repaired. The best
> speculation is that flanges on the axel, which used to keep the sealed
> bearings tightly in place, have worn over the years, and now allow the
> bearing to slide back and forth on the axle. Does anyone who has
> experienced this problem know the answer?
I haven’t had this problem, but I will do some idle speculation. My Schwinn is
about 15 years old and my wife’s is from the same era. The bearings on both of
them freely slide sideways along the axle but neither one wobbles. I wonder if
you just may need new bearings. You can get them from the Unicycle Factory
(see FAQ).
Beirne
Beirne Konarski | Subscribe to the Unicycling Mailing List bkonarsk@mcs.kent.edu
| Send requests to unicycling-request@mcs.kent.edu “Untouched by Scandal” |
Unicycling WWW: http://www.mcs.kent.edu/~bkonarsk
Re: axle wear on a Swchinn 24" (fwd)
>Forwarded message:
>> Dear One-wheelers,
>> spite of having consulted many people, I do not have a clear explanation
>> for this problem, and hence don’t know if it can be repaired. The best
>(see FAQ).
>Beirne
I’ve never mey a schwin, so I dont know it’s construction. However, if the
problem is that the bearings are loose on the axel, you could try pulling them
off then shimming with a thin sheet of metal. Just wedge a collar of the metal
round the shaft before forcing the bearings back on. Soft drinks cans are
excellent - although the steel ones may work better than the aluminium.
Rik
