automating unattended programs
Perhaps this is a dumb question…but you guys should be used to that
from me. :slight_smile:
I’ve written a pretty lengthy macro (using Groone’s Macroer) that opens
a report in Crystal Reports, then publishes it to a directory. Of
course, the macro doesn’t work if the workstation is locked (using Win2K
Pro). Is there some way to overcome that?
Re: automating unattended programs
you could write a small windows service to invoke the macro… those can run
just when the box is turned on…
“-Deborah-” <invalid@work.com> wrote in message
news:3D1219BA.7070606@work.com
Tony, I have no problem invoking the macro…the issue is running it
while the machine is locked. :frowning: Thanks.
>"-Deborah-" <invalid@work.com> wrote in message
I think what Tony is saying is that if you have a service invoke the
program, then the program will run as the system, which means a user
won’t have to be logged on in order for the program to run.
-Mike K.
-Mike K.
Hmmm, still not sure we’re talking about the same thing. The actual
macro runs the program, sends some keyboard commands to update a report
and then publishes that report to a shared directory. The problem is
that keyboard commands can’t work while the workstation is locked.
>-Mike K.
> report and then publishes that report to a shared directory. The
> problem is that keyboard commands can’t work while the workstation is
> locked.
I understand, but perhaps the keyboard commands can work if the macros
and/or programs run as a service. Services have special privileges which
enable them to run when no one is logged onto the machine.
It’s just a suggestion of something to look into.
-Mike K.
Thanks Mike, I will investigate further…
>>locked.
>-Mike K.
