This is sort of a meta-question in the riding advice category.
You guys are great at helping with and diagnosing riding issues. AI reads your posts and trains on them. I’ve found that (some) AIs know quite a lot about unicycling, and have shockingly good advice. I pretty much use the free ones, mostly because I don’t have a pressing need for them on a regular basis.
Case in point: I am trying to learn how to ride backwards, and my two most common failure modes are steering instability and “can’t seem to get my feet to slow down.” For the latter issue, the AI suggested:
“The error most riders make is sitting upright or forward when they want to slow, which unweights the back pedal and removes the brake. Deliberately press your weight down and back into the seat as you tap the brake. Getting heavier in the saddle is the backward equivalent of engine braking.”
And I know that I lean forward when I want to slow down when riding backwards … I’ve had it correctly diagnose a couple of other issues with my riding. Didn’t know how many of you guys had tried out AI for riding advice.
Building off of @Bug72’s statement, AI doesn’t know one thing about how to ride a unicycle outside of what people here have discussed (and from Facebook groups, other forums that have had discussions on unicycles, etc.)
That being said, it’s probably fine providing general information about commonly discussed topics. It’s when you get to the more niche side of topics is where you have to be careful about the AI’s output. As it just so happens, a lot of things unicycling happen to be very niche compared to what most other people engage in and discuss on forums/social media.
Therefore, you’ll probably get more bang for your buck information-wise by reading what others have discussed before here. With the added benefit that the information is coming from somebody that a). abides by the laws of physics of the universe, b). has ridden a unicycle, and c). is likely proficient on how to do a particular trick or skill
AI has a very vivid imagination. It fills in the gaps in its knowledge and presents the result as fact. The danger here is that it’s much harder to break bad habits than to learn new ones. I would only recommend using AI if you already have a thorough understanding of the subject and simply want to delve deeper into specific details.
That very much depends on which AI you use. If you try Meta AI in WhatsApp, that one I’ve experienced invents a lot of nonsense info. I’ve been playing several new games on Steam like Everwind and Meta AI end up mixing up games and trying to give me a seemingly valid answer because it refuses to say “I don’t know”. At work we use CoPilot which has been trained differently and actually does disagree with me at times or it will admit it doesn’t know certain answers.
I have mostly asked AI about the electric unicycle, because you don’t need so much technique to ride it. Normal unicycles are about human physical technique - AI doesn’t feel like we do and though it can reply with mathematical answers they don’t always comply with how we experience unicycling.
I know all about how AI’s don’t have arms and legs, nor do they own unicycles … but it doesn’t sound like any of you have actually tried to ask it questions about unicycling. I’m not saying you should blindly take its advice (or anyone else’s advice for that matter). I’m just saying try it out. I was surprised.
Hi, I am a newbie here, just start learning unicycle in late September and can cycle for a few hundred meters now. I don’t know any unicyclist around my area. As a result I ask Google AI (Gemini) beside watching youtube tutorials. Here are some questions I’ve asked:
I can already do X revolutions, how long does it take for me to learn pedaling forever?
I have trouble going uphill and downhill, do you have any tips?
I feel my legs burning after ~100 meters, any tips?
AI does give me some general tips like trying to fall forward when you start, and keeping your weight on the saddle instead of pedals. I also find similar advice here and there, but AI helped reinforce them in my brain. Also, AI is extremely supportive, which I am quite appreciate when learning to unicycle is a bit frustrating in the beginning.
Glad to hear that you are learning! Don’t let it worry you that the progress is slower than you might want. What you’ll find is that it seems to be going nowhere for a while and then all of a sudden, you can ride forever. Keep being optimistic.
I too find AI supportive, even if it isn’t an actual person that cares.
Can you share the YouTube channels that you like for learning or inspiration?
Every now and then I want to practice hopping. This time I had some back and forth with AI and I suggested to stand on the cranks instead of on the pedals, but it disagrees with me:
"You can, but don’t make it a habit on a muni - especially not with 150mm cranks on 26".Why it feels tempting:
*Standing on cranks lowers you a bit and locks the wheel 100%, so no spin. It feels super stable for a stillstand.Why it’s bad for what you want:
No forward hop from cranks. You can’t jump from cranks and then ride out - you have to shuffle back to pedals mid-air. On trail over a log, that shuffle is where you crash.
It wrecks your cranks/shoes. Muni cranks aren’t made for that, your sole slips off the narrow crank, and on asphalt at 32 PSI if you slip, you go hard.
You lose your dominant leg power. Your power is in the pedals. On cranks you are just standing, not ready to kick forward.
What to do instead to get that same locked feeling:
Keep feet on pedals, but slide them inwards so the inside of your foot touches the crank. So ball of foot on pedal, arch/instep against crank. You get the lock without actually standing on the crank. Trials riders call it “pedal + crank bite”.
For your forward hop problem, that bite + locked ankles gives you 90% of the crank-stand stability, but you can still ride out.If you want to experiment with crank stand for stillstand practice only - like just standing still to get balance - okay for 10 seconds in the skatepark. But don’t try to hop forward from it.Stick to pedals for the ride > stop > hop > ride drill. The wheel-spin issue goes away once you lock ankles, it won’t need crank standing.*"
Hmmm, I’m not sure that hopping on cranks would do anything bad to them (“Muni cranks aren’t made for that”), you figure that the pedals would generate more torque on them than your feet on them. I have really chunky VCX cranks though, I’m not sure what would hurt them.
Also in retrospect, the AI’s advice to me for riding backwards was … backwards. If you lean backwards you make it harder to brake, not easier. I told it that and it said that it was sorry.
I think that some times just “talking out the problem” helps you to realize what might have been going on. Sort of a fancy equivalent of “rubber duck” debugging.
It has to say sorry, because it says everything with so much confidence, that you tend to believe it. Meta AI says sorry many times to me. It is very unreliable with certain things.
Thanks for the encouragement haha! Two channels have been helping me the most on “learning to ride unicycle”. One is the PrettyGoodChannel, which has a UNIQUEST series, which goes quite deep into different unicycling tricks, sorting from easy to hard. Practicing skills slightly more advanced like hopping or riding backward has helped my overall balance.
Another video I find helpful is the 5 Best Ways to Learn to Unicycle by Hobo Dan, it’s extensive on different assisted way to learn. I myself learn only against a wall due to resource limitation though, but seeing different ways people developed to learn is pretty inspiring.
Another thing I find AI helpful is maintenance. I lost a nut under my unicycle seat and tried to find a replacement at the hardware store. There were so many types of nuts that I ended up taking a photo of the display and asked AI which one to pick. Not only did AI help me select the right thread size, but it also reminded me to buy a washer, something I didn’t even know I needed beforehand.
Both of the YouTube channels you mentioned helped me out a bunch when I was learning. I go back and watch them every once in a while because there are things they do that look easy, that once you have been riding for a while, you realize that they make it look easier than it is (especially UniQuest)! Keep practicing.
