I know that the bearings are 40mm so I would need to shim them… I was just wondering… I would like to upgrade the frame first and eventually the wheelset. I may just ride the DX20 until I’m ready for a whole new uni…
if you put shims on the bearings it will fit for sure, my friend is riding a 24" Torker wheel with a KH24 frame(with shims). If you dont the bearings will move a little bit in the bearing holders, I had a square taper hub in my KH frame last year(testing a 16" wheel) without shims.
Oh, and you’ll have to get some spacers for your cranks also because the cranks will rub on the frame.
