Hi, I would REALLY apretiate it if a 700c (29") KHXC owner could measure from the center of the bearing holders, to the top of the frame for me, i’d EXTREMELY apretiate it, thank you!
Brett,
(Not to the very top, but to the highest point of tire clearence ‘the bottom of the crown’)
the KH29 XC frame measures: inside leg 354mm, though the center of the inside of the crown is 17mm higher than this. you can add another 0.5mm to this as there is 1mm gap between the bearing cups, these measurement were with a steel rule so are mostly accurate but not brilliant.
