Another beginners' question
Still in the 10’ distance range, but creeping along. I have a late 80’s Schwinn
with bolt on cranks (not the pins). Would it make much difference or hurt if
replaced the stock chrome steel cranks with late model aluminum models, about
1/2-3/4" longer?
I am 6-0" and the seat is up all the way, and needs to go further. This will
help out and drop a few pounds off. Any comments…
Re: Another beginners’ question
–WebTV-Mail-1466746728-153 Content-Type: Text/Plain; Charset=US-ASCII
Content-Transfer-Encoding: 7Bit
It should not be necessary to change the cranks on a 24" (or 20" for that
matter) Schwinn for normal riding. You’ll find that with a little more riding
that the cranks will begin to feel more and more comfortable. They make a 14"
seat post that should do you just fine. Contact a Schwinn dealer or The Unicycle
Factory. Good Luck, Mike
–WebTV-Mail-1466746728-153 Content-Disposition: Inline Content-Type:
Message/RFC822 Content-Transfer-Encoding: 7Bit
Received: from mailsorter-102.bryant.webtv.net
(mailsorter-102.iap.bryant.webtv.net
[207.79.35.92]) by postoffice-131.iap.bryant.webtv.net
(8.8.5/po.gso.24Feb98) with ESMTP id UAA29967; Thu, 30 Jul
1998 20:09:03 -0700 (PDT) Received: from
icicle.winternet.com (icicle.winternet.com
[198.174.169.13]) by mailsorter-102.bryant.webtv.net
(8.8.5/ms.graham.14Aug97) with ESMTP id UAA17623; Thu, 30
Jul 1998 20:09:01 -0700 (PDT) Received: (from
server@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
VAA22426 for unicycling-outgoing; Thu, 30 Jul 1998
21:54:54 -0500 (CDT) X-Authentication-Warning:
icicle.winternet.com: server set sender to
owner-unicycling using -f Received: (from adm@localhost)
by icicle.winternet.com (8.8.8/8.8.8) id VAA22328 for
<UNICYCLING@WINTERNET.COM>; Thu, 30 Jul 1998 21:54:15
-0500 (CDT) Received: from auvm.american.edu(147.9.1.2) by
icicle.winternet.com via smap (V2.0) id xma022305; Thu, 30
Jul 98 21:54:04 -0500 Received: from AUVM.AMERICAN.EDU by
AUVM.AMERICAN.EDU (IBM VM SMTP V2R2) with BSMTP id 6354;
Thu, 30 Jul 98 22:46:46 EDT Received: from
AUVM.AMERICAN.EDU (NJE origin NETNEWS@AUVM) by
AUVM.AMERICAN.EDU (LMail V1.2a/1.8a) with BSMTP id 2968;
Thu, 30 Jul 1998 22:46:46 -0400 To:
UNICYCLING@winternet.com From: “Joe Mayers”
<acadian@eatel.net> Newsgroups: rec.sport.unicycling
Subject: Another beginners’ question Date: Fri, 24 Jul
1998 11:53:23 -0500 Lines: 9 X-Newsreader: Microsoft
Outlook Express 4.71.1712.3 X-MimeOLE: Produced By
Microsoft MimeOLE V4.71.1712.3 NNTP-Posting-Host:
tnt1-228.eatel.net Message-ID: <35b8bed3.0@news.eatel.net>
Path: auvm!paladin.american.edu!zombie.ncsc.mil!news.ultr-
anet.com! feed2.news.erols.com!erols!howland.erols.net!su-
nqbc.risq.qc.ca!wesley.videotro
n.net!Pollux.Teleglobe.net!uunet!in1.uu.net!news.eatel.net!tnt1-228.eat-
el.net Xref: paladin.american.edu rec.sport.unicycling:5929 Sender:
owner-unicycling@winternet.com Precedence: bulk Reply-To: “Joe Mayers”
<acadian@eatel.net>
1/2-3/4" longer?
–WebTV-Mail-1466746728-153–
I would get a longer seatpost. If you don’t find one at a Schwinn shop, you can
order one from The Unicycle Factory at 765-452-2692.
Beirne
> Schwinn with bolt on cranks (not the pins). Would it make much difference or
> hurt if replaced the stock chrome steel cranks with late model aluminum
> models, about 1/2-3/4" longer?
