hi there: im looking for informatin on, or directions to a page showing
easiest way to mount my 6 foot chain drive. 25 years ago i began on a small
unicycle, slowy progressing up, i would ride in events, but could only ride as
far as i could, then walk back to a wall and ladder to mount again. getting
frustrated at not being able to free mount i lost interest, but getting onto
the web and seeing sites like this one has brought back my interest. thanks
Re: an easy way to mount?
Hey, I just got a six footer three weeks ago and would love to know if there is
a secret. Jack Wiley’s Complete book of unicycling suggests learning using a
curb or a 4 X 4 to block the tire then climbing up the wheel. No luck for me so
far. But hey, I was excited just to be riding up so high.
Let me know if you find any secret trick or if you actually freemount. I am
working on it too. John
>Received: from [198.174.169.13] by hotmail.com (1.0) with SMTP id
MHotMail308707765130235065324943333335309536660; Wed Oct 28 17:34:26 1998
>Received: (from server@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
>TAA06745 for unicycling-outgoing; Wed, 28 Oct 1998 19:03:50 -0600 (CST)
>X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicycling using -f
>Received: (from adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
>TAA06634 for <UNICYCLING@WINTERNET.COM>; Wed, 28 Oct 1998 19:03:07 -0600 (CST)
>Received: from auvm.american.edu(147.9.1.2) by icicle.winternet.com via
smap (V2.0)
> id xma006604; Wed, 28 Oct 98 19:02:45 -0600 Received: from
> AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM SMTP
V2R2)
> with BSMTP id 8882; Wed, 28 Oct 98 20:04:59 EST Received: from
> AUVM.AMERICAN.EDU (NJE origin NETNEWS@AUVM) by
AUVM.AMERICAN.EDU (LMail V1.2a/1.8a) with BSMTP id 7854; Wed, 28 Oct 1998
20:04:54 -0500
>To: UNICYCLING@winternet.com Path:
>auvm!paladin.american.edu!zombie.ncsc.mil!newsgate.duke.edu!
nntp-out.monmouth.com!newspeer.monmouth.com!newsfeed.wli.net!su-news-hub1.bbnp
> lanet.com!news.gtei.net!newsfeed.concentric.net!webtv.net!not-for-mail From:
> relicmine@webtv.net (David Keller) Newsgroups: rec.sport.unicycling Subject:
> an easy way to mount? Date: Wed, 28 Oct 1998 14:45:35 -0600 (CST)
> Organization: WebTV Subscriber Lines: 10 Message-ID:
> <18563-3637826F-92@newsd-171.iap.bryant.webtv.net> NNTP-Posting-Host:
> localhost.webtv.net Mime-Version: 1.0 (WebTV) Content-Type: Text/Plain;
> Charset=US-ASCII Content-Transfer-Encoding: 7Bit X-WebTV-Signature: 1
ETAsAhNFJ0cFg6co9P5lFdBJKvEd/W2gAhUAwLocGKjIAyoFp01P6KuTZo+JkG8=
>Xref: paladin.american.edu rec.sport.unicycling:6489 Sender:
>owner-unicycling@winternet.com Precedence: bulk Reply-To: relicmine@webtv.net
>(David Keller)
events,
>but could only ride as far as i could, then walk back to a wall and ladder to
>mount again. getting frustrated at not being able to free mount i lost
>interest, but getting onto the web and seeing sites like this one has brought
Get Your Private, Free Email at http://www.hotmail.com
RE: an easy way to mount?
(Re: giraffe freemounting)
> Jack Wiley’s Complete book of unicycling suggests learning using a curb or a 4
> X 4 to block the tire then climbing up the wheel. Let me know if you find any
> secret trick
I took a brief look this morning on unicycling.org for giraffe mounting
information and didn’t notice any. It’s probably in there somewhere but not
easily indexed. So here is the short, short version of how to do it:
What do you need a curb or block for? All it will do is keep you from riding
in that direction if you get up there. Standing on the bottom pedal will hold
the wheel in place just fine. -
Stand up the uni in front of you, facing away from you or partially to the
side. If the unicycle is low enough or you are tall enough, you can step
directly to the bottom pedal. But usually you have to step on the tire first.
I use my dominant foot on the tire, so my non-dominant foot goes on the
bottom pedal. My dominant foot is the one I mount with on a regular unicycle.
So when you start, your non-dominant pedal will be down. -
step on the tire with your dominant foot. By placing that foot right where
the tire meets the frame, nothing will go anywhere. -
Put your non-dominant foot on the bottom pedal, and stand up on it. Don’t
crouch and don’t hang around in this position. -
Swing your other leg over/around the seat, and get your butt on the seat
before going for the other pedal. This is key unless you want to ride away
seat in front. -
Your dominant foot will hit the top pedal from the front, pushing it
backward. This puts the unicycle into a forward lean, and you have to start
riding away. Also you are no longer in the dead spot so you can do so.
TIPS:
7. If you can’t idle or ride backward and you’re trying to freemount a giraffe,
you’re learning things in the wrong order. Giraffe riding is very unsafe if
you can’t back away or idle when you need to. Learn those first.
Don’t play with different pedal angles before mounting. It doesn’t matter. As
soon as you step on the pedal it will be straight down, so plan accordingly. -
Don’t play with different angles to tilt the unicycle before you climb up
it. It doesn’t matter what angle you use. The only thing that matters is that
you be more or less directly above the wheel when you get up there.
Generally tilting the unicycle a little away from you allows you to run up
there and then pull the seat under you to end up directly on top. -
Practice in stages. Do step 3 and stop, standing on top of the tire as
long as you can. find the balance point in this position. When that gets
boring, do the same thing standing on the pedal. Remember to stand fully
up on the pedal. -
Safety! Practice falling down from step 4 to all points of the compass. If
you know what to do when the unicycle goes down, you’ll be ready and less
likely to be hurt. Eventually, you will go down in every possible compass
direction. -
Repitition! It took me uncounted tries to get it the first time, and that
was at age 17. Expect it to take a while. But if you practice enough,
eventually you should be able to do 130 in a row. I did once. – I can’t
remember why though!
Stay on top,
John Foss, the Uni-Cyclone http://www.calweb.com/~unifoss/
“Insert clever quote here”
>5. Safety! Practice falling down from step 4 to all points of the compass. If
less
>direction.
Ahhh, wise words from our great teacher. I did this step only after learning how
to limp, due to many failed freemount attempts.
I also found it easier to do it in stages. I started by freemounting a 4
1/2 ft. uni before attempting a 5ft and then finally a 7ft.
“Tah tan gah”
Wayne van Wijk
This message is in MIME format. Since your mail reader does not understand this
format, some or all of this message may not be legible.
------_=_NextPart_000_01BE0423.8ADBA13B Content-Type: text/plain;
charset=“iso-8859-1”
John Dibble wrote:
> idle. I am continuing to try and improve those skills. Riding the Giraffe
> seems a little tough but I am able to ride done the block and turn at
> this point. I find the massive amount of play in the wheel from the
> chain to be the hardest thing to get used to.
If yours is like mine (it is, but mine’s a 5’), the play comes from the crank
arm moving back and forth in that little hole in the top sprocket. The peg that
fits the hole is smaller than the hole, and there’s your play. I had the same
problem in the past with my Schwinn, and tried all sorts of ways to shim it up
or otherwise tighten the two parts together. Nothing worked for me until I
finally had the two parts spot welded together.
If you have additional play, like in your chain, it might need tightening.
Sometimes you get a sprocket that’s off-center (usually the bottom one). This
will limit your ability to tighten it. The main thing is not to be so loose
the chan can come off, or so tight the chan creates lots of friction in the
wheel motion.
Stay on top,
------_=_NextPart_000_01BE0423.8ADBA13B Content-Type: application/ms-tnef
Content-Transfer-Encoding: base64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-
AEA MDJHVTCfdS6h/SqyZCKAH8ACIAdAK3MzEP8yEyvRPnMtszMQMsEyYEXxviAm4DAiReQgA-
R8QUzTx /x/AB4JNki/CJHA5xjfzM7FxK1BmLWMJ8A6wBcAo/TAAdUnjJxMeECBAH3Am0f4pO-
kIpEQPwQxEk kDJgBUD/PnMBoAMQJKBVcSBRReUkoN86RADAK9MgAikRbktxLhS7Q0AkgG8hk-
i11A6BjXBL/NPFU QjMQBbFbIUXTW6kYIP8owAeRF7BDdANQDeBOYivG7yzEBGBOYkybUwGQI-
JBf0e85gTMQTKodM0Yh kDMBItLCVQMALUN5YxewJuADHlRGAHRwOi8vd9VmAC5cQGxLoGJmM-
ANwXC9+KxAGkGPxL0yqIt5J AIAEkAVAZOBlIUAFwFxxdR4RLqA+ESIeVH0BalAAAB4AcAABA-
AAAFwAAAGFuIGVhc3kgd2F5IHRv IG1vdW50PyAAAAIBcQABAAAAGwAAAAG+A7muOUEHnkhvq-
xHSrEAAoMmECcsAGjI3kAADAC4AAAAA AAsAKwAAAAAACwACAAEAAAAeAEIQAQAAACkAAAA8M-
Tk5ODEwMzAwMzU5NTAuMjY2NDUucW1haWxA aG90bWFpbC5jb20+AAAAAAMA3j+vbwAAQAA5A-
EBIq4ojBL4BAwDxPwkEAAAeADFAAQAAAAwAAABG T1NTLCBKT0hOWAADABpAAAAAAB4AMEABA-
AAADAAAAEZPU1MsIEpPSE5YAAMAGUAAAAAAAwD9P+QE AAADACYAAAAAAAMANgAAAAAAAwCAE-
P////8CAUcAAQAAADIAAABjPVVTO2E9TUNJO3A9SW50ZWw7 bD1GTVNNU1g0NS05ODEwMzAxN-
jM3MTBaLTU4NTQ3AAAAAgH5PwEAAABNAAAAAAAAANynQMjAQhAa tLkIACsv4YIBAAAAAAAAA-
C9PPUlOVEVML09VPUFNRVJJQ0FTMDEvQ049V09SS0VSUy9DTj1GT1NT LCBKT0hOWAAAAAAeA-
Pg/AQAAAAwAAABGb3NzLCBKb2huWAAeADhAAQAAAAwAAABGT1NTLCBKT0hO WAACAfs/AQAAA-
E0AAAAAAAAA3KdAyMBCEBq0uQgAKy/hggEAAAAAAAAAL089SU5URUwvT1U9QU1F UklDQVMwM-
S9DTj1XT1JLRVJTL0NOPUZPU1MsIEpPSE5YAAAAAB4A+j8BAAAADAAAAEZvc3MsIEpv aG5YA-
B4AOUABAAAADAAAAEZPU1MsIEpPSE5YAEAABzBtbk8DIwS+AUAACDA7oduKIwS+AR4APQAB
AAAABQAAAFJFOiAAAAAAHgAdDgEAAAAXAAAAYW4gZWFzeSB3YXkgdG8gbW91bnQ/IAAAHgA1E-
AEA AAAyAAAAPDk5QkFBMEVGNEIxMEQyMTFBQzQwMDBBMEM5NUJGOTQwM0JBMjREQEZNU01TW-
DQ1PgAA AAsAKQAAAAAACwAjAAAAAAADAAYQLtHmcAMABxCEAwAAAwAQEAAAAAADABEQAAAAA-
B4ACBABAAAA ZQAAAEpPSE5ESUJCTEVXUk9URTpJRExFSUFNQ09OVElOVUlOR1RPVFJZQU5ES-
U1QUk9WRVRIT1NF U0tJTExTUklESU5HVEhFR0lSQUZGRVNFRU1TQUxJVFRMRVRPVUdIQlVUS-
UFNQUIAAAAAAgF/AAEA AAAyAAAAPDk5QkFBMEVGNEIxMEQyMTFBQzQwMDBBMEM5NUJGOTQwM-
0JBMjREQEZNU01TWDQ1PgAA ACE3
------_=_NextPart_000_01BE0423.8ADBA13B–
> > 4 X 4 to block the tire then climbing up the wheel. Let me know if you find
> > any secret trick
John is right, the giraffe mounting page is buried (its under the fun things to
do section). The URL is http://unicycling.org/unicycling/mg.html. The main
thing the page adds over John’s advice is pictures of Wolfgang Stroessner
mounting a 9’ uni.
Beirne
