Amazing new trials frame
That is a sweet lookin’ frame. The pins are a cool idea although I wouldn’t be able to use them just yet(although I am learning).
Can’t wait to see one in real life. What is the proposed damage gonna be? I’ll have to start saving now I think.
Nice!
Man, I want one. Can anyone give weight comparisons to other popular frames (Nimbus 2, KH 20, and any others)? I assume we’re looking at a price over $250 American:( ? Would you want to sell any prototypes or anything? I’m looking to lighten my uni, with the hopes that it will improve my jump. Seeing those pins also makes me want to prectice stand up ww. Just curious, has anyone had their chlothes caught by the pins?
Can’t wait till January, I hope to be able to scrape up the cash for one soon.
GerbilFranklin,
I currently have the three above mentioned frames (2 20" and 1 24"). And as I said if I still have them and Mr. Atkins hasn’t blown his up, I’d be comfortable selling two of them for a discounted price. The other one, I’m currently riding and would like to keep for it’s sentimental value.
As far as retail goes, it’s still up in the air. I want to keep it reasonably priced, but they’re not cheap to make. I’ll have a better idea after I talk to John Drummond from Uni.com. Chances are they’ll be a bit more than 250 American.
I’ve yet to have the set screws interfere with any of my riding. they are set in pretty far on the crown and I doubt anyone will catch their pants on them.
Thanks again to every for the encouraging responses.
How much does the 24" frame weigh? Has it also been stress tested?
Thanks
Just checked out the pictures and that frame is the coolest thing I’ve seen in unicycles lately. Nice job on the crown.
I remember when they were still made from paper. Its nice to see the real thing.
ORigami MUni’s??
link
Yes, Origame. It’s the new coolest thing. lighter than composits and unbelieveable ride quality…
Sal is referring to my origianal “model.” the frist two frames i made were constructed of a machined seat tube and bearing clamps. the legs and crown were constructed of two peices of sheet metal. same shape and general design (without the mill work on the crown) but a entirely monocoque design. I had a paper cutout of the laser cutting file all scotch taped together and was showing the guys who came to flint. It wasn’t very elegant and i don’t think anyone really could see what they were going to look like from it, but at the time it seemed like a good idea.
I have two 20" frames constructed in this manner from mild steel. they are very stong (could hardly move the material to align it after welding) but very heavy. they were early prototypes of what were going to be sheet aluminum versions, but they would have been too hard to make in quantity and there was over sixty inches of weld on a twenty inch frame. all the welds are ground off of the one I ride and it looks pretty sweet. i’ll post pics if i ever get one of those camera contraptions.
Merril,
Wieght on the trials frame without the steel bearing holders was 1 pound, 4 ounces. the frames that ryan and jeff are riding have steel bearing holders for street style riding. ryan has requested a pair of aluminum replacements that i will be making for him this week.
the 24" frames will come standard with aluminum bottom clamps (steel will be an option for those interested) there isn’t much material in the bearing clamps, and aluminum is light, so add three ounces for that maybe. other than that the frames are the same except there is three more inches of leg between the bearing holders and the crown, add maybe another ounce.
I’m pretty sure the final weight, including my magura mounting idea (flush mount, so when you’r not using brakes there are no bosses,) will way an oune or two more than the wilder frames posted weight of 1.44 pounds.
As far as Stress testing goes, My swanky new dell laptop should arrive in the nest few days on which i plan to run Some FEA Analysis using Altair Hypermesh (Plug for the company i work at: Altairs analysis software is the whip.) these results will be reflected in the final production design. I don’t see much changing though, the same seems very over built even at it’s current low wieght. if anything guage analysis on the seat tube and leg material will lead to a lighter stiffer frame.
Current “stress” testing for the trials frames are being done by Ryan and Jeff, who seem pleased thus far, though it’s been only a few days of riding. When I get back to school, Kettering University (check the website, apply there, I need somone to ride with) I’m going to throw one on a tensile and compression testing machine and see what it takes to blow one up.
That’s all for now. thanks again to everyone, without constantly reading this forum I could never have gotten this far.
I especially liked the pins on the crown, a great innovation! Because they are screws, riders should be able to adjust them for less grip if they get too hung up.
Like Nathan said, if it holds up under Ryan Atkins, it should work for anybody!
The frame looks nice and the folded sheet for light weight and strength is an interesting concept which you have proven is workable. How do you do the tight folds? Over a mandrel?
I would recommend staying with a steel bottom clamp for the bearing holders. They don’t add much weight. The advantage of having a split holder here is that the bottom can be armored. I’ve seen how quickly the bearing holders get banged up doing crank grabs that miss slightly. The aluminum would get gouged too quickly. The aluminum bearing holders on my SH MUni sport some nice, deep scars. The KH trials uni that I have just shows scratches.
You do the heat treating to T6 after all the welds, I presume? Do you accurately know the weight difference between one of the CrMo trials frames and yours with the required bearing hardware attached?
Anodized finishes are fantastic. And, by the way, if you want that frame tested, don’t let Jeff or Ryan use it…they’re too graceful. You need a klutz like me banging it up. I land like a buffalo.
Mr. Harper,
Indeed the frames were solution treated and artificially aged to a hearty T-6 post weld. It took me over a week to find someone in the motorcity willing to do such a small job. I was suprised at how few companies deal with treating aluminum.
As far as the leg construction goes, It’s my little secret. But since I’m so impressed that you recognized the difficulty of the task I suppose I can let it out. When I get the materials from the lasercutter the two bends on the outside of the legs are complete, the bends on the inside of the leg are at about thirty degrees. The legs in this state were then taken to numerous sheet metal shops where I was laughed at, aked to leave and even kicked. I was told repeatedly, “sorry, there’s nothing we can do for you.” who’d of thought that making a boxed section with a single seam could have been so hard? Certainly not me.
So I went home and cried for a little while and then made two fixtures that hold the leg with it’s outer face down. I then tap in a carefully machined “anvil” that fills the inside of the leg. Aluminum plates with a cammed lever rotate on hinges to bend the aluminum just past 90 degrees. when I let go, they magically spring back to form a perfect right angle. At this point I usually dance around a bit, chug a beer and scoot over to welding table*.
I’m with you on the steel bearing holders. I like the idea but realize the some people don’t use their frames as roughly as others. The aluminum ones will be an option for those who care more about a few ounces than a few dollars to replace a marred peice of aluminum. Maybe i’ll even make them in titanium…
I remember your enthusiasm toward anodizing from a while back. I am Friends with Roger Rodrigues, owner of BRISA (they make trials bikes.) He has recently been using a frame finish that i think he calls a “glow anodize.” The frame is shot peened with a course media, leaving a gritty texture all over it. Each frame is then Dipped in something (looks like chrome plating but it isn’t) after the mystery plating is done the frames receive a translucent anodized finish. These frames look absolutley beautiful! you can see a dark shiny reflection through the anodizing and the texture of the frame reflects the light very well.
If these sell well I will definately be looking into that proccess. all i really know about it is that it looks incredible and it isn’t cheap.
Well my fingers hurt, so it’s time to go.
If Blue shift ever needs a new frame feel free to contact me. just think of it, your hub, my frame traveling the world, seeing things i’ve only ever read about, or at least skimmed through looking for something else to read about.
*Mike Pritchett does condone nor does he actually participate in drinking and welding.
i like trials frames:D
Hey Mike, I’d be honored to buy one of those frames, assuming Ryan and John don’t destroy them. PM me if they get returned, and we could negotiate a price.
more pics!!!
I was just wondering what you wanted more pictures of Aust?
I think that the photos Ryan put up cover just about all aspects of the frame.
Jeff
hey,
that frame is sweet! my friend and i are thinking about getting one late august or sooner. he just likes the silver but i think im gonna go with the black powder coat…sexyness. both goin for the steel bottom bearing cases. i’ll e-mail with more details.
Ðevon
Cool . . .
Since I ride a lot of steep dirt single tracks and long descents down fire roads, I’d sure like to have the option of Magura brakes on the 24"er.
A quick look at rock climbing gear (especially caribiners) might give you some ideas per coloring aluminum. Painting alum. is actually pretty “cave” compared to what you can do these days, but I suspect the fancy colors on climgbing gear are possible because of the high numbers. But a red or orange or even blue anodized finish would be smokin’, and the color wouldn’t chip off. Couple rides with the boys up at Santa Barbera (exceedingly rocky trails) and my KH24 looks like it’s been fed through a wood chipper.
JL
Just in reference to the color thing 2 pages ago, “Any color you want, as long as it’s black” was the Ford Model-T slogan.
I agree about the coloring. But, I THINK there might be a technical problem with the anodizing. The frames are hollow and I think the frame has to be completely sealed for the anodizing to work. If there is even a tiny hole, it might present a problem. For solid aluminum, it works well as with climbing safety gear.
Someone correct me if I am wrong. The Steve howard MUni frames are anodized, but not hollow, as far as I know.
That is one sweet frame…good job semper_uni. Does anyone know how long it would take to make one of those frames?
Karl
