Also I like to tell in close advance of this event (in the hours and days before) I though I heard spokes breaking a couple of time, but when checking all pairs I couldn’t discover anything, no saw anything odd, while being fully convinced hearing something was wrong.
The breaking must have took place is stages, which is a good thing. Better than ti that usually breaks suddenly in once.
Also I think the fatal factor (straw that broke the camels back) might have been the freezing cold temperatures.
That’s depends who’s ridiculous opinions you repeat for a a fact, without thinking for yourself, or more important; experiencing for yourself.
I’ve been riding that pattern for over 19 years. Did many pair stuff. I never encountered such failure before, while doing MUCH crazier stuff than just riding.
Semcycle assembles like this for almost 30 years. AFAIK never any such alike failure.
But; it’s not the pattern that is the problem…
if you repeat the combination is wrong, then I agree (with my own words), especially when finally admitting these hubs are not strong enough for me because of the flange being to small.
But not because the “lacing is wrong”. Why is it wrong? Because the hub can’t deal with it, not because the pattern.
In your previous paragraph that was a question, now a statement. But I hope you are more wisely repeating my opinion now.
If you read carefully, then that hub size and material combination is such that I myself was not surprised we broke it: I predicted that myself in the same thread in advance.
Although the hub design doesn’t fit with me, I don’t blame Mad4One, which is still my top 3 of prefered hubs, but after Semcycle and after Exceed.
Don’t be surprised to see me dropping ISIS for that.
I do not wish to defame Mad4One, which is pushing the weight factor, on price of strength, however still also offers more strength because of the lack of welds. And not unimportant: incredible precise! Therefor an excellent hub. But for us with a limit I dislike, but for you this is all irrelevant.
I remember very well my very first conversation with Marco.
It pleases me to hear he indirectly seem to admit I was right.
Although I still would like to see that Facebook statement exactly quoted.
No, you see that incorrect; it’s cross 1
No it should not be different, at least not for us, but for your type of riding, I guess yes likely.
IMHO it makes nicer unicycle wheels. I was in doubt to try cross 1.5. But if a hub now suddenly cannot deal with that anymore, then the hub is not good; not the pattern. The unicycle is serving us, not opposite.
Ha, sounds like you have the same spirit about breaking stuff
When listening to the video you can even hear parts hit the ground!
I wasn’t pissed at all, only about losing practise hours.
Further I’m happy to went trough this on exactly a very critical position, and being able to deal with it. In the video you can see my partner instantly received the message trough my muscles. A sudden blocking wheel and breaking pedals are my biggest fear while doing risky stuff.
I cannot recall I’d broke one single spoke in that hub. Ever.
Using the Italian Alpina Raggi (sold under the BMX label of Pr1mo).
OK, for the record, I didn’t knew this model now seems to carry the label freestyle. Back then it was the trial one (light, Ergal), and the ChroMo one (heavy), meant for freestyle. I’m not available on Facebook for sport-unicyclists and alike, so I missed the memo. But just to set the record straight;
CroMo = reinforced?
Ergal = freestyle?
Why not using the manufacturers terminology/naming …?
That’s minimal visible. But freaking annoying, as it makes the cranks move (only a bit, but when doing pair acrobatics pretty scary).
I showed it confidentially (on personal basis) to Olaf, however my partner and I do not wish to disclose the circumstances when this occurs publicly to anyone else (nor to anyone of Mad4One). Ask me again after next UNICON, if you haven’t find out during.
But I’m willing to let you hear the sounds (in slow motion) of that skill, you can count the number of pins squeeking.
That problem is entirely solved by eliminating the pin system.
For you pins are a good thing, I do like them, it is smart and I think very good, though in our case they are not an option, although a double amount of pins probably would have worked better.
Having a 2nd look at the pins, I now notice that the traces of wear are only on one of the two surface parts that made contact.
Further the pins were extreme tight (I’m happy I finally got them out using long/strong pinchers patience and some luck). I was very surprised to hear people could remove them without tools.
Again; these were prototypes, so also here I do not call this “bad failure”, but “acceptable failure”.
I think it’s the pins being to soft. Maybe the sizing was wrong.
That I’m sure to!
It depends on what you desire. For you yes, for me no. And an old fashioned freestyle hub never had any problems with that (nor doesn’t require an overstressing tention, which the narrow flanges do).
LOL, yes, I think so to.
