More IDLING tips
Since, Iâve recently STOPPED for a bit and starting back up, I have noticed a few details that might help some riders.
The difference between âpressing downâ and âpulling the pedalâ.
Ideally, when adding âcontrolled weightâ to the pedal it would be like simply applying a piece of lead. Perfectly controlled amount of force to be perfectly applied during the whole clock cycle of the pedal.
Unfortunately, we are man not machine.
We must rely our âoverpowerâ leg muscle to be able to nimbly apply just the âright amountâ of force and be constant whether the pedal is at 6, 12, 3,âŚetc. position.
Only a very advanced or gifted beginner has the ability to apply perfect pedal force in perfect rotation. Most of us can only âsense/feelâ this:
a.) Applying downward pressure on pedal. Apply too much = pedal speeds up in an unwanted manner. Just right = applying force but doesnât over-rotate. This is not steadily applied, because it only happens during downward vertical part of rotation.
b.) Applying âpullingâ pressure on pedal. Apply too much = again, pedal speeds up. Also, not steadily applied, because it is applied when pedal is at the top and sweeping back from say 11 to 1 oâclock.
Just being aware of these two directions of applying force to the pedal will put you on the road to controlling both, and then ultimately developing a âfull clock rotationâ of constant pedal pressure.
Why is this important?
a.) Advanced Idling
b.) Backwards riding.
You may be at a âsticking pointâ in trying to get better. Killing yourself to thinking that it will never happen. Will power alone is not enough, but breaking down and understanding the mechanics involved may help you. For me, I would have never ever been able to ride with the âapproachâ of just doing it.
âŚslam
