Adobe Premiere Pro - render settings.
Hello all! :smiley:
I gave up with sony vegas, it didn’t like me, so i downloaded adobe premiere pro.
I’ve worked out the basics of it, and rather like it, however, I can’t get it to render well.
I have a test clip uploading now, which i will post when it’s finished, which is all jumpy, even though it is still a big file (30 seconds - 90MB)
Does anyone have a good set of render settings they can reccomend, i’m just uploading to youtube, so theres no point rendering over 30FPS.
Thanks!
Ali
seriously? I cant edit?
okay
http://www.youtube.com/watch?v=KcVBkFYWA1g
there’s the video, the quality is way less than it should be. :frowning:
Do you plan to do more with the program? Instead of pirating a few hundred dollars, for titles, fades, and cuts, you might as well stick with windows movie maker.
Rendering settings are pretty common sense, premiere has a lot of useful presets too. Id start there, and even googling up some guides.
Check your bitrate from source material.
I do Jerrick :slight_smile:
I fiddled and got a slightly better result, with h.264 (mp4)
And if it annoys you that much, the only thing I was doing with this video was familliarising myself with a new program.
