I made a uni movie in adobe and want to export it to a smaller file size for uploading onto my gallery. I have tryed over 30 times with many diffrent settings and can not get it small enough, most of my movies have turned out to be about 209mb and some have even came out to 3gb. Can someone PPPLLLEEEEAAASSSEEE Help me??? I have looked on google 100 times and cant fine a good tutorial.
If you’re going to compress it in WMM you’ll get a wmv, in which case you might as well just use Premiere to export and convert it to wmv in one step. I believe the option is under File -> Export -> Adobe Media Encoder or something like that. I don’t have Premiere installed currently right now so I can’t check.
From my experience exporting it to wmv works fine, the only problem you get is when you try to export to some compressed avi format.
To compress in VirtualDub open the exported file in VirtualDub, go to Video -> Compression and select and configure the codec you wish to use, then go to Audio -> Full Processing Mode -> Audio -> Compression -> select the audio codec you wish to use.
You never said what format you want the final file to be in, so what do you want it to be?
