Even if the seat or seat post are out of whack, you should be able to adjust your posture and sitting position.
If the uni leans right, it is either the tire or the rider, more often it’s the rider.
Try raising or lowering your seat
OMG! i really hope its not this! it does sound like it could be though… but ive tried loads of other unicycles and never had this problem before.
If this was the case, what would the solution be? is there any kind of training I could do to solve it?
btw, thx to everyone for the feedback so far, it may not seem like much but it has been really helpful!
Do you know any other unicyclists nearby? Instead of just trying other unicycles, have someone else ride yours. If they agree it’s leaning then it’s not you.
I took the advice found on several threads here, and added a few of my own, and the problem is almost completely gone:
Mine took a long time to cure because it got so bad I had a muscle imbalance and had to learn to restrain one side while developing the other. I found the hip rotation to be a fascinating thing to work on. There is an article here you might find interesting.
Hopefully though, the problem is the uni and not u! Good luck.
Dont overlook the possibility that it could be a few things all effecting the problem a little each… Fix the seat, then check the spokes / rim/ hub, and then move on to … An hour tweaking and perfecting make for several extra hours of enjoyment… Plus it enables you to become more intimatly familiar with the cycle incase something ever does go afoul…
I use to preach this with race cars… Fix all the little things and youd be surprised that that BIG problem went away.
Sounds like good marriage advice.
I think that your problem might be that you turn one direction more than the other and therefore that side of the tire is more worn and lower than the other side, causing you to turn that way.
If you have an omnidirectional tire, you could try to flip the tire and see if you lean the other way. Leave it like it like this, and eventually, it might balance out.
