Keep riding trust me you cannot go wrong. I learned at 48 the 36er I’m 60 now. When I first learned I stuck to all the rules of learning. Now I do pretty much what I want on the 36er.
I used to Tear fried going over bumps and also of small curves. Now I eat that stuff up. Keep riding you’ll get there in no time👍🏾
Okay, Iwool
You are getting a lot of motivation/inspiration but not enough direct instructions.
Basic control and manipulation of the unicycle, your body and balance.
How you can learn this from just simple from wall practice(holding on).
Understand and develop a “feel” for the unicycle ability to TWIST.
a.) Just tighten your thighs against the saddle
b.) Use upper torso, shoulder even head to “initiate” a twist force.
c.) This is first way to manipulate unicycle steering. Especially, against a wall.
d.) When holding wall or rail, try to grab at “lower” position near hip so that you are not “hanging on wall” like a rope. The ideal practice rail = tennis court net. It’s low and allows mobility while still having stability from falling. This applies to the rest of this topic. -
Understand and develop a “feel” for Tilting fore/aft.
a.) Here is the “trick” you do not actually “lean”
b.) Your system(body, unicycle) controlled by your feet and pedal rotation, only.
c.) Get used to not only pedaling forward but also backwards.
d.) Not just direction, but the “acceleration and stopping” your feet = pedal is control.
e.) Do this enough time, it becomes “automatic” and your fears of falling are gone.
f.) Now, you know how to correct falling forwards and backwards. -
Understand and develop a “feel” for lateral(side to side) balance
a.) Simply weight pedal, either left or right to balance = either left or right.
b.) Easy to do when pedals are at 3 & 9 o’clock or flat position.
Easy to see the “teeter totter” analogy for lateral balance.
c.) The “trick” is that when one pedal is up and one pedal is down. Still apply the same lateral balance control. However, one knee is up and one is down = complexity to control weight distribution. However, with enough practice you master this.
At this point, you have mastered 95% of the unicycle dynamics to be able to at least go 3 or 4 pedals before falling. The missing ingredient is one of two things:
a.) “superior” balance as in what a circus tight rope walker can attain. This is impossible to teach and the term “weight on saddle” becomes an unattainable dream.
b.) “coordinated weight on pedals”. Combined with a dynamic moving side to side balance and counterbalance. This is the brute force mechanical method of balance. This works for for most “never quitters” who are “not born unicycle riders”.
c.) At this point, I am guilty of over-loading you with information. However, I hope there is some details that might help you.
…slam
Hmm, I was going to reply in this topic and say “Just GO FOR IT, launch from a post in a smooth flat area (like a basketball court), first experiment with getting balanced while holding the post, then allow you plus the unicycle to lean forward, and attempt to keep upright by starting to pedal - remember to step off quickly forward when losing control and don’t worry about catching the unicycle - I reckon anyone who is mildly fit and keen, has reasonable eyesight and reaction time can learn in a few weeks at most”. But then I thought I would ask the dreaded AI (in the form of Gemini), and I got the following good response (quite likely partially inspired by comments in this forum, or even this thread!) …
Learning to Conquer the Wheel: A Considered Review of Approaches to Unicycling
Riding a unicycle, that seemingly whimsical mode of transport, often appears as a feat reserved for circus performers or the exceptionally coordinated. Yet, as you rightly point out, it’s a skill accessible to many, even entire classrooms of pre-teens. While rigorous, peer-reviewed scientific studies on unicycle pedagogy might be scarce, a wealth of anecdotal evidence, community consensus, and logical biomechanical principles can guide a novice from their first tentative wobbles to confidently gliding 100 meters and beyond.
The journey to unicycling proficiency is indeed one where opinions abound. However, common threads emerge, pointing towards effective strategies that can make the learning process quicker, easier, and less fraught with tumbles.
Common Approaches to Learning Unicycling:
Several methods are commonly employed by aspiring unicyclists:
The “Wall Hugger” or “Fence Crawler”: This is arguably the most common starting point for self-taught riders.
- Method: Using a wall, fence, or railing for support, the learner practices mounting, finding their balance point, and making initial pedal strokes. The goal is to gradually reduce reliance on the support, eventually pushing off and attempting short, unsupported bursts.
- Pros: Readily available, allows for self-paced learning, builds initial comfort with the feel of the unicycle.
- Cons: Can lead to leaning heavily on the support, hindering the development of true balance. Transitioning away from the wall can be a significant hurdle.
The “Human Crutch” (Assisted Learning): Involving one or two helpers.
- Method: Assistants provide support by holding the learner’s hands, shoulders, or even the unicycle seat. This allows the learner to experience the sensation of riding and pedaling with a greater sense of security.
- Pros: Can be reassuring, helps in overcoming initial fear, allows focus on pedaling motion and subtle balance adjustments with external stabilization.
- Cons: Over-reliance on assistants can hinder independent balance development. The quality of assistance is crucial; helpers need to provide support without over-correcting or hindering natural learning.
The “Open Space” or “Fall and Learn” Method:
- Method: After mastering basic mounting (perhaps with initial brief support), the learner moves to an open, grassy area and repeatedly attempts to ride, accepting falls as part of the process.
- Pros: Encourages finding true balance more quickly as there’s no external support to lean on. Falling on grass is generally safer.
- Cons: Can be initially frustrating and involve more falls. Requires a degree of resilience and courage.
The “Ramp” or “Slight Incline” Method:
- Method: Some suggest starting on a very gentle, smooth downward slope. The slight momentum can make initial balancing and pedaling feel easier.
- Pros: Can help with the initial sensation of continuous movement and reduce the effort of the first few pedal strokes.
- Cons: Requires finding a suitable, safe incline. Controlling speed can be an added challenge for a complete beginner. Transitioning to flat ground is still necessary.
Structured Learning (Workshops, Clubs, Online Tutorials):
- Method: Following a curriculum, often developed by experienced riders or clubs. This can include specific drills, progression steps, and tailored advice. Online video tutorials are a very common resource.
- Pros: Benefits from the distilled experience of others, often provides a clear progression, can offer troubleshooting for common problems. Community aspect of clubs can be motivating.
- Cons: In-person instruction may not be readily available everywhere. Quality of online resources can vary.
Key Principles and “Good Ideas” for Quicker, Easier, and Less Painful Learning:
Despite the varied approaches, certain principles and tips consistently emerge as beneficial:
- Focus on Weight Distribution: The core of unicycling is learning to keep your weight centered over the wheel. This means putting most of your weight on the seat, not the pedals. Beginners often make the mistake of standing on the pedals, which makes balancing much harder.
- Look Ahead: Just like riding a bicycle, looking where you want to go (10-20 feet ahead) rather than down at the wheel helps immensely with balance and direction.
- Small, Consistent Pedal Strokes: Avoid jerky, large movements. Smooth, relatively quick (but controlled) pedaling is key to maintaining momentum and stability.
- Arms for Balance: Use your arms outstretched to the sides for balance, much like a tightrope walker.
- Practice Mounting: Efficient and consistent mounting is a foundational skill. Practice getting on the unicycle smoothly until it becomes second nature. Many recommend starting with the cranks in a vertical or near-vertical position, placing one foot on the lower pedal, and then pushing up and forward onto the seat while bringing the other foot to the other pedal.
- Learn to “Dismount” or “Bail” Safely: Falling is inevitable. Practice stepping or jumping off the unicycle forward, letting the unicycle go behind you. This minimizes injury. Avoid trying to catch the unicycle or putting your hands down in awkward ways.
- Choose the Right Unicycle: A beginner unicycle with a smaller wheel (e.g., 20-inch) is generally recommended as it’s more maneuverable and the falls are from a lower height. Ensure the seat height is correctly adjusted – when seated with a pedal at its lowest point, your leg should be almost straight with a slight bend in the knee.
- Appropriate Learning Environment: A smooth, flat surface is ideal. Grass can be good for softer landings but can make pedaling harder. A clear, open space away from traffic and obstacles is crucial. Indoor spaces like a gym or basketball court can be excellent.
- Patience and Persistence: This is perhaps the most critical element. Learning to unicycle takes time and dedication. Progress often comes in spurts, with plateaus in between. Don’t get discouraged by falls or slow progress. Short, regular practice sessions (e.g., 20-30 minutes daily) are often more effective than infrequent long sessions.
- Protective Gear: While not always emphasized by seasoned riders, beginners can benefit from a helmet, wrist guards, and even knee and elbow pads for increased confidence and protection against minor injuries.
Can You Teach Yourself Without Any Help?
Absolutely. Many, if not most, unicyclists are self-taught, primarily using the “wall hugger” and “open space” methods, often supplemented by online resources. The key is determination and a willingness to experiment and learn from your mistakes (and falls).
Recommended Practical Approach:
For an absolute novice aiming to ride 100 meters on a flat surface, a blended approach is likely most effective:
Preparation & Gear:
- Acquire a suitable beginner unicycle (20-inch wheel is a good start).
- Ensure correct seat height.
- Consider basic protective gear (helmet, wrist guards) for initial confidence.
- Find a suitable learning space: a smooth wall or fence next to a clear, flat area (e.g., a netball court, quiet car park, or even a hallway initially). An open grassy area is good for later stages.
Phase 1: Getting Comfortable (The Wall is Your Friend - Temporarily):
- Mounting Practice: Stand next to the wall. Position the unicycle with the cranks vertical. Place the ball of your dominant foot on the lower pedal. Hold the wall with one hand and the unicycle seat with the other (or both hands on the wall). Push down on the pedal and simultaneously lift yourself onto the seat, aiming to get your other foot onto the opposite pedal quickly. Repeat until mounting feels relatively smooth.
- Finding the Balance Point: Once mounted and holding the wall, try to sit upright, putting your full weight on the seat. Gently rock back and forth, trying to find the point where you feel balanced over the wheel, even if just for a second.
- First Pedal Strokes (Assisted): Still alongside the wall, try making half pedal strokes, then full pedal strokes, using the wall for light support. Focus on keeping your weight on the seat and looking ahead. The goal is to minimize pressure on the wall.
Phase 2: The Launch (Moving Away from Support):
- Push Off and Go: Once you can pedal a short distance alongside the wall with minimal contact, try pushing off from the wall and riding a few feet into the open space. Aim for a specific point ahead.
- Embrace Short Rides: Initially, even one or two successful, unsupported pedal strokes are a victory. Gradually try to increase the distance.
- Controlled Dismounts: Practice stepping forward off the unicycle when you lose balance. Don’t fight the fall; just step off.
Phase 3: Building Consistency (The Open Space Challenge):
- Move to an Open Area: A smooth, flat area (or forgiving grass once you have some control) is now your primary training ground.
- Focus on Kilometrage (Meterage!): The key now is repetition. Mount, ride as far as you can, dismount, repeat.
- Refine Technique: Pay attention to looking ahead, keeping weight on the seat, and using your arms for balance. Try to make your pedaling smoother and more continuous.
- Dealing with “Uh-Ohs”: When you feel yourself losing balance, try to make small, quick pedal adjustments or upper body movements to correct. If you can’t save it, dismount safely.
Phase 4: Extending Duration and Distance:
- Set Small Goals: Aim for 5 meters, then 10, then 20, and so on.
- Practice Turning: Once you can ride straight consistently, start practicing gentle turns by twisting your hips and shoulders in the direction you want to go.
- Free Mounting: Eventually, you’ll want to learn to “free mount” – mounting without any support. This often involves placing the unicycle in front of you, one pedal down and slightly back, and then stepping up onto it in a coordinated movement. There are several techniques for this, which can be explored once basic riding is established.
Addressing the “No Scientific Testing” Point:
While formal scientific studies comparing unicycling teaching methods may be lacking, the principles of motor skill acquisition still apply. Learning unicycling involves developing:
- Proprioception: Your body’s awareness of its position in space.
- Balance: Complex neuromuscular coordination.
- Fine Motor Control: Subtle adjustments in pedaling and body position.
The recommended approach leverages these by:
- Progressive Difficulty: Starting with support and gradually removing it.
- Repetition and Practice: Essential for myelinating neural pathways and automating movements.
- Feedback: Both internal (how it feels) and external (seeing how far you rode, or advice from others/videos).
- Minimizing Fear: Using supports and safe falling techniques reduces anxiety, which can inhibit learning.
Conclusion:
Learning to ride a unicycle is a rewarding challenge that is well within reach of a determined individual. While there isn’t a single, scientifically proven “best” way, a practical approach combining initial support, a focus on core balance principles, consistent practice in a safe environment, and a resilient attitude will significantly increase your chances of success. Embrace the wobbles, celebrate the small victories, and soon you’ll be experiencing the unique joy of gliding on one wheel. And yes, you can definitely teach yourself, armed with good information and a good dose of perseverance.
I think you should ask Gemini to do an abstract. Cause by the time a beginner has finished reading the instructions, he would be close to be able to ride a unicycle if he had followed the „just try it, don’t give up!“ route.
OK, I got an abstract and then a summary of the abstract, so here goes:
Learn to Ride a Unicycle (by Yourself, on a Netball Court)
Step 1: Use the Fence to Get Started
- Stand beside the fence with your unicycle.
- Put one pedal down and step on it.
- Use the fence to help you get onto the seat and place your other foot on the top pedal.
- Sit fully on the seat—don’t stand on the pedals!
Step 2: Get a Feel for Balance
- Hold the fence lightly and try to stay balanced.
- Keep your weight on the seat, not your feet.
- Practice small, smooth pedal movements while holding the fence.
Step 3: Push Off and Ride
- When you feel ready, take a deep breath and push away from the fence.
- Look ahead (not at your feet!) and try pedaling 2–3 strokes forward.
- If you fall, step off forward. That’s normal!
Tips to Remember:
- Sit down! The more weight on the seat, the better.
- Look ahead. Where your eyes go, your body follows.
- Pedal smoothly. Small, steady strokes work best.
- Use your arms for balance. Hold them out like airplane wings.
Practice Strategy:
- Ride for short sessions (15–20 minutes).
- Expect lots of wobbles and falls—they’re part of the process!
- Celebrate little wins, like one extra pedal stroke or riding a few meters.
What about for Tips to remember : Leave the wall/fence as soon as possible, or you will be glued to it while learning. It may act as a magnet.
Also for once you’ve covered the beginner steps, try to keep your airplane wings folded inwards and stop flapping. Maybe first with one hand on the seat and over time both hands on the seat and balance with your hips instead of the upper body. Sometimes I my hands crossed in front of my chest or together on my back with the lack of handle bars. Or just loosely hanging to the sides.
That‘s short enough for me to bother reading it. And I think it‘s not halfway bad.
Could still be a bit more condensed, but it shouldbe quite helpful as it is.
I would prefer a wall to a fence because I always fear for their fingers to get caught in a UPD when I see beginners using a fence. Also, I encourage beginners to at some point „get up to speed“ by the help of the wall and then leave it instead of just pushing away from the wall. I also do this when I practice wheel e.g. walk. But I‘m aware that I‘m possibly in a minority with this approach. My impression is that most people teach to just push off the wall (and hope for the best).
It depends a bit on what the fence looks like. The fence I use for UW consists of cm think bars and the top is flat so I can slide my hand over it if needed. A wall is harder when it is too tall. I learned riding while living alone, holding the kitchen surface and then have 2-3 meters to get free of it ending in the corner of the small living room
Okay, that‘s more like a railing than a fence, then. I‘m automatically thinking of chain-wire fencing…
Hey, Chris! Thanks for the note and encouragement. That profile pic of you on that giant wheel? That’s kinda anxious making – and inspiring. I appreciate you took the time to write
Thanks, Slamdance. I read every word. Some I don’t get, but I’m betting I will as I progress. Much appreciated.
Thanks, gocup and, I guess, Gemini. This is good and useful stuff. I like the listing of a variety of approaches. ChatGPT helped me break down my practice into very, very micro steps. A quarter turn of the pedal, for instance, back and forth against a wall. I appreciate you took the time
Excellent advice, I think. And leaving the wall/fence is destined to be soon: I’m taking the unicycle on vacation, and I don’t see me spending my time searching for a suitable wall. Thanks for the guidance.
So, I weened myself from the fence three days ago, and my success so far is not pitching the unicycle over the 15-foot fence that surrounds the courts on which I practice, thus making the beast irretrievable.
Maybe one out of 12 times I can get past the dead zone. What I learned today, though, is that my right foot has much more trouble with that than my left. So, I’m back to the fence practicing half rotations with my right foot going through the dead zone.
These micro lessons, created with the help of ChatGPT, are certainly useful. This is the part, though, where I acknowledge your contributions. Because while I’m out there, I find myself repeating in my mind, pretty much word for word, guidance I’ve received here.
Thank you, many times over.
Brian
Great minds think alike. After a really bad crash when my lace wound Into my peddle, I switched all of my shoes to Bungie laces. I also ride with slip on vans, probably not the best shoe but I love them.
Sounds like you’re really close, and it’ll “just click” soon now. Keep it up!
The first few feet of unassisted unicycling are probably the most difficult few feet for many riders. The good news is after you conquer those first few feet, things gradually get easier from there ![]()
In our backyard there’s a small stretch of concrete pavement leading to a garage, which is where I learned to ride unassisted. I would mount the unicycle next to a wall, point myself away from the wall, and push myself away from the wall and try to ride. To me it was like a baby bird being pushed out of the nest in order to learn how to fly… Except I wasn’t very good at it
I would push myself away from the wall and immediately fall off the uni (landing on my feet most of the time).
It was like that for what felt like a pretty long time. The stretch of pavement conveniently had lines in it spaced about 9 feet apart, which I used to gauge my progress instead of counting revolutions. It took a lot of effort to hit the first line in the pavement, and even then I couldn’t do it consistently. Still, though, it felt like a huge achievement when I did hit that milestone. Then I started to aim for the second line at around 18 feet, and celebrated when I hit that. The third line at 27 feet was still very difficult but didn’t take as long as the first two lines. I think after I was able to ride from one end of the driveway to the other, things just kinda took off from there.
With enough persistence, I’m positive you’ll get there
The last is of a great importance!! Your brain needs some time to “shake in” the skills you have just got.
I started with that a crasy activity @66 years young, almost 5 years ago. The only my unhappiness in this respect was that i did not started with that earlier.
Good luck to you!
And another couple of advices.
Give up a wall ASAP. Say, after you can do full rev of the pedals. Otherwise you will get the “skill” to catch the wall rather than to keep a balance in a free space.
With the wall, try to do it both sided.
One more remark.
I wasted a lot of time starting with a 26" with 127mm cranks and 1.95" tire.
When I were starting now, I would use a 24" uni with 137mm cranks and 2.4" tire.
I’m hopeful for the click, kinda counting on it, and I appreciate the encouragement. That means a lot. Thank you.
Thanks for the encouragement – and for sharing a chunk of your early journey. I’m going to work out something similar on the court I’m practicing on. Counting revolutions is a bit tricky when trying to be mindful of all the nuances. Much appreciated.
Yeah, I’m realizing that…
Thanks for the age-defying inspiration. I feel the same way about wishing I started sooner…
I’m done with the wall for anything other than a new skill, like getting my right foot to reliability go back and forth over the dead zone. Once I get a rhythm with that I’m off the wall unless something else pops up. And in the meantime, I plan to still make my assistance -free attempts, as opposed to riding along the wall, which I realized isn’t riding at all
I’ve wondered if a 24" muni would be better, but am sticking with the highly recommended 20" because, well, that’s what I bought 'cause of that highly recommended bit.
Thank you for taking time to encourage and advise. Means a lot to me.
