Re: A unicycle for riding on water
Text item:
Beirne wrote:
>It turns out that all sorts of creative geniuses are working on unicycles. I
>went back to the IBM patent server (http://www.patents.ibm.com/ibm.html) and
>found a unicycle that can be ridden on the water (assuming that it really
>works). I’ve put the patent documents at http://www.unicycling.org/unicycling/
>patents/wateruni/.
I checked this one out too. The writing was atrocious! It also reads like an
advertisement. As an editor I could have improved it tremendously by cutting out
at least 2/3 of the text, which repeats itself over and over.
The design has a wheel with a water jet at the bottom. It looks like the rider
would be mostly underwater, at least up to the chest. Therefore, when pedaled,
the wheel would move forward and up, until the rider was nearly on his back
before making any significant movement forward. Real useful.
To see a far more practical water unicycle, look here:
http://www.calweb.com/~unifoss/thingnot/dontdo.htm#26
Not incredibly useful, but probably a lot more fun!
John Foss
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: beirne@neo.lrun.com Precedence: bulk Sender:
owner-unicycling@winternet.com Date: Mon, 09 Mar 1998 00:07:56 -0400
Content-Type: text/plain; charset=us-ascii Mime-Version: 1.0 Subject: A unicycle
for riding on water To: unicycling@winternet.com X-Mailer: exmh version 2.0.2
2/24/98 Received: from neo.lrun.com (a13b051.neo.lrun.com) by
akron5.neo.lrun.com with E SMTP
(1.40.112.8/16.2) id AA035016476; Sun, 8 Mar 1998 23:07:56 -0500
Received: from akron5.neo.lrun.com by
akron4.neo.lrun.com with ESMTP
(1.40.112.8/16.3) id AA287886477; Sun, 8 Mar 1998 23:07:57 -0500 Received:
from akron4.neo.lrun.com(204.210.219.65) by
icicle.winternet.com via s map (V2.0) id xma024554; Sun,
8 Mar 98 22:08:00 -0600 Message-Id:
<199803090408.WAA24625@icicle.winternet.com> From:
beirne@neo.lrun.com Received: (from adm@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id WAA24625 for
<unicycling@winternet.com>; Sun, 8 Mar 1998 22:08:32
-0600 (CST) X-Authentication-Warning:
icicle.winternet.com: server set sender to owner-unicy
cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id WAA24714 for
unicycling-outgoing; Sun, 8 Mar 1998 22:09:07 -0600 (CST)
Received: from icicle.winternet.com (icicle.winternet.com
[198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5)
with ESMTP id UAA21474 for <JohnX_Foss@ccm.fm.intel.com>;
Sun, 8 Mar 1998 20:40:07 -0800 (PST) Received: from
thalia.fm.intel.com (thalia.fm.intel.com
[132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3)
with ESMTP id UAA11810 for <JohnX_Foss@ccm.fm.int
el.com>; Sun, 8 Mar 1998 20:36:02 -0800 (PST)
Return-Path: unicycling-owner@icicle.winternet.com
