A splined Hub on a Torker LX
do u guys know of a splined hub that would work on a 2006 LX, im looking to make my LX stronger than it currently is
Check two things:
  1. Hub width, usually from flange to flange.
  2. Bearing size, by outer diameter.
If you can find a splined hub with close measurements for those two things, then it should work. Although I tend to doubt it’s possible.
Nah it just has to be within like a cm all together. You can usually bend the legs out on a steel frame.
why would you want to do this? get a better frame too.
Frames are usually the last thing that needs to be upgraded.
